traction control question 00 WS6
The way you can tell if you have it , Is to look on the back side of the rear brakes behind the tire and see if there is a wire plugging into a sensor there is a reluctor ring that is pressed on the axle in front of the axle seal ,that were it reads if the tires slips or brakes loose , That is called 4 channel ABS or Traction Control, if you don't it , you have 2 channel ABS with out traction control.
if you have it you WILL know it. It pushes your foot off the gas when the tires loose traction, and there will be a switch on the dash as well as that motor under the hood with all the cables going to it. You can't miss any of it.
I have a 01 WS6 with M6, no switch of course, light on the dash at startup. I have seen the light come on once or twice in the 8 years of driving it, only came on when driving on snow or ice just driving normal, caught my attention and I was like...never seen that light come on before lol. Not a GM expert but I assume it sees slip in the rear thats light enough that the dif doesnt catch it. Correct me if I'm wrong, but yes, I've seen the light come on during driving.
Moderator
I hate my tc on my 02 ws6 m6. i get on it forgetting to turn it off and my gas peddal literally goes soft and feels mushy. scares me cause i think i broke something lol. also my skip shift. what in tarnation was gm thinking on that... i cant baby it shifting 1st to 2nd. like car is saying, "noooo take me to 3k rpms before you shift me."
