Best ramps for a trans am?
I went to Napa today and got some sturdy looking metal ramps but I noticed that they only had a 2000 lb weight capacity and the Trans Am is somewhere around 3400 isn't it? I'm afraid to buy those plastic ramps that I've seen sold elsewhere since they look like they'd crack in a heartbeat, so I was wondering what kind everybody else uses.
EDIT: Wait I'm an idiot aren't I? That's like 2000 lb per ramp so... heh. I was wondering why metal would be so flimsy.
Rhino Ramps FTW!!!!! Easier to use then jack stands and safer as well......since your car can't roll off them if you are properly seated on them (and on a flat surface obviously). A set of four works great if you need to slide under you car safely and keep the suspension loaded (bolting in SFC's for example) or just a simple oil change. ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
FWIW, I also have 4 jack stands when I need that higher lift but the ramps are WAY easier to use since you just drive onto them and don't have to jack your car up in 2-4 different places (1 per stand).
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
well i guess i am with every one else. I love my ramps so easy for those quick little jobs just drive up do what you have to and back off. And when i did the clutch in my car i drove the front on to the ramps then just jack stands to lift it a little higher. that way the car falls it just falls on to the ramps. just never did trust the stands when i am trying to stab the trans back in
Bringin this thread back cause I just picked up some gray rhino ramps do these work well also with lowered cars? I had always used a jack and jack stands but I just got this car and its a pain to get a jack under. So with the ramps i figured I can drive on them and then if I need to go higher use the jack from there. Will make oil changes alot easier also glad I got them.
The cars weight doesn't equal that over the front or rear tires, and each ramp can take 2000lbs, so if you have more than 4000lbs up front, something is wrong
You'll be fine, but as noted, watch for nose scrape!
![Tongue](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_tongue.gif)
Originally Posted by SpdFrk1990
Thats what i was wondering about do they work well with lowered cars?
Its stock height for now but I might lower it 1.25" or so b4 long.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
