FTI Torque Converter Track Results!!
tony, like Rich said, i was driving his 09 GT with the 3600 converter. you can definitely feel there is a converter there from stop to about 30 mph, but its not loose like a 3600 in an fbody or vette. i believe its due to the massive gearing in the 6L80e transmission. if you like a tight feeling converter, btu still want that feeling of flash - i would probably go down to a 3200, but i wouldnt go any lower than that. personally, i would roll out with the 3600 b/c it performs so well.
Did you get to cruise with it locked at any time? Just wondering if it carries some of the lock-up quirks I've seen with the larger stalls.
Interesting. That's was my main concern on going with a stall that size was that "loose" feeling like the fbodies have. I wasn't sure if the manners would be better or worse with the 6L80.
Greg at FTI builds some super converters. I told him what I wanted in a dd converter and he built it better than what I asked for. ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Check out the times in my signature below and my time slips are posted in my personal best post.
Tony
Tony
LS1Tech Sponsor
Born 2 fly, very nice times. Congrats. After much work by fellow GTO board member Blast2hell FTI'S new website is up and going. Check it out. We have a readers ride section to put in your pics and the home page will be updated weekly with performance reports from all of our customers so send in your results and we will post them. We also have a mailing list section to recieve updates and info regarding new product and press releases. Check out the calender to see where FTI will be testing ,vending or racing. Thanks again for all of your bussiness as without you we could not reach the next level. Thank you!!!!
Greg
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
1-866-726-8358
FTIPerformance.com
![](https://ls1tech.com/forums/signaturepics/sigpic99412_4.gif)
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
FTI 3600 has my G8 going pretty well down the track!
Couple questions now that I've had it a while...
Do you know what would cause the converter to chatter? It seems to work fine otherwise. Chatters in park, goes away in Reverse, chatter comes back in neutral, goes away in drive.
Any idea why the car leaves harder off idle then it does loading up the stall? Theres no tire spin to speak of on MIR's well prepped track. If I leave off idle up to about 1200RPM she goes 1.6x, stall it up to 2-3k RPM she goes 1.7x.
The 3600 now flashes about 4k RPM with my power. Are their any changes recommended either way to make the car faster?
Thanks
Thanks
