boosting the g8
#41
got the flanges here. i wish they were a little thicker >> http://www.verociousmotorsports.com/...-2-Bolt-Flange
yes i did order a pump. i went all out and got the expensive exa pump. http://www.turbowerx.com/Scavenge_Pu...FRBM5QodsiR7fQ
#46
i got the other turbo/wg set up done and bolted on. both turbos are permanently installed on the car. i had to clock them a little and clock one of the wg's. i fired it up for a sec to check for exhaust leaks and found none.
thats it
. not enough time in the day. i should have 100% of what i need to finish it once i have time.
thats it
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
#55
they have the nicest bends i have seen. some bends loose their shape when you cut them but not theirs. you can cut and clock a bend and it is perfectly round mid bend.
expensive. a 3" is $25
i wont be geting a converter anytime soon but when i do it will probably be a Circle D. i like the one in our wagon. if i am ready i might be going to mam next friday.
#60
I'm flying back monday and installing the new trans and restalled converter(3800) tuesday. I have to run around monday and find a shop to swap the bellhousing and then its ready to go.
