need some good engine bay photos...
LS1Tech Sponsor
we have a G8 GXP in the shop that we are doing a 427 build for. Well the car was at the dealership first because the customer was hoping they could cover it under warranty.
The dealer took the car apart and then denied his warranty so when the car showed up at our shop, the motor was out of the car along with a lot of stuff that should have never been removed.
I need photos of the main fuse block and all the wiring that runs from it down in front of the engine and over to the alternator and charging post on the drivers side.
Just some good random shots of the engine bay should do fine.
Thanks.
Thanks.
http://forum.grrrr8.net/showthread.php?t=9094
There are some pics in this thread and plenty on the site. I have some at home I can post later.
LS1Tech Sponsor
a thousand miles or so after that, there was a rod hanging out the side of the block.
warranty denied due to "abuse" acording to GM.
long story short, if you are thinking about modding your G8 but hessitate because you want to save your warranty.....dont bother. Go ahead and mod the hell out of it because they will deny your warranty anyway.
with less than 1500 miles on a bone stock car, multiple valves hit multiple pistions. GM in their infinite wisdom simply replaced a some pistons and valves, rather than giving the guy a new motor.
Not sure if this helps, but it shows a lot of detail when viewed at full size.
![](https://farm3.static.flickr.com/2560/3753584095_98a0620926_b.jpg)
(Full Size to show detail)
http://farm3.static.flickr.com/2560/...c0018381_o.jpg
*edit. One more I took after I installed my headers.
![](https://i258.photobucket.com/albums/hh275/redpile/headers/9.jpg)
You could but these if you don't want to look at them.
http://www.forum.grrrr8.net/showthread.php?t=3425
