G8 vs Cobra
Thanks yeah made 630 rwhp no meth straight 93 pump gas..just that 11.0 it was the last day the track was open,got 2 runs befor i got the boot... 1st run was a 11.19@121 went from 3rd to 5th
2nd run 11.0@127 the trans was having issues but we are working on the 6L80E tune to get everything right...
No just hobb set @5 psi and over turns the BAP on to 100% under 5+lbs of boost...then back to reg when driving around under vac. its the hobb switch kenne bell sends with the BAP kit. It got cranked up to 100% the the BAP **** was removed and fused together,so it couldn't be hit/knocked/tampered with with out me knowing,an go out to play and not have enough fuel could hurt the motor...
