06 gto fuel rrails and injectors.....will they fitt on my 04 gto?
ok my buddy has the 2006 injectors and fuel rails and i have an 04 gto and was wondering if they will fitt?
thanks guys
thanks guys
Couple of things to keep in mind..
- LS2 injectors are much shorter than the LS1 injectors
- LS2 and LS1 injectors have different wiring plugs, so you'll need harness adaptors
- LS2 fuel rails will not bolt directly onto an LS2 intake.. LS1 fuel rail bolts are offset from the intake bolt holes, while the LS2 stuff is directly in-line.
