Drag bag tubing
Drag bag tubing
Picked up a set of drag bags and got them mostly installed up to the T fitting. Just have to run the tube to the trunk. The guys on ls1gto are telling me to run the bags separately instead. How did you guys run your lines? Any advice?
Here is the writeup I reffered to.....
http://www.ls1gto.com/forums/showthr...ag+bag+install
Hope this helps
I have mine ran seperatly. My right rear squats morre than the left so I have the right one around 6psi and the left at around 3psi. You can zipties and run the lines up through a hole that goes up into your trunk. I lables the hoses left and right.
Hope this helps
Hope this helps
i have them too. i ran them seperate. i put them in the fender right infront of the tire just drilled a hole and mounted them there. so that way when you let some air out of your tires or put some air in then the drag bags air valve is right there (less going back and forth)
Oh ok. 10-15 seems to be the norm. 20 is getting pretty high I was told. I just put mine in about 2 weeks ago, but I haven't had a chance to try them out yet. Everything is just tucked under the car and zip-tied for now as I ran out of time to get the hoses ran into the trunk.
Body roll from getting into hard turns will be worse with the bags combined. Pressure on one side will just bleed air into the opposite air bag.
Running each bag independent is the way to go.
As with everything I do, threw together another video. lmk if you guys like it!
http://www.youtube.com/watch?v=fTU-L...&feature=inbox
