GTO bell housing / crank specs
I'm trying to order a bell housing alignment tool for my GTO, they asked for the bell housing opening and crank register size, is this information I can get from the factory specs?
I never heard of a bell housing alignment tool. Are you sure that you don't mean the clutch alignment tool? Walt and I have had my bell housing off and on 3 times and never needed any tool to align it.
Yeah look up Browellbellhousing.com , but unfortunately they do not offer one large enough for the stock Tremec housing. Most people probably don't check the bell housing alignment but it's critical for the long life of your input shaft / bearings and pilot bushing / bearing. If I was using a pilot bearing I would definitely check it, I believe the spec is .003
Stock bell should be fine. Adjustable dowels can be bought should you want to pursue this with a custom made tool or dial indicator method.
You always want to check aftermarket units. The thing with them is, most have paint or Powdercoat that will interfere with a true reading unless it's carefully removed.
Yeah its been proven though that GM was horribly inconsistent with casting and a stock housing on stock dowels more times than not is out of spec, unfortunately I put the cart before the horse and already have offset dowels. I have a dial indicator and magnetic base, I'm going to check the stock alignment the old fashioned way ha! The Browell tool would have been significantly easier but that's how it goes I suppose!
Old small n big blocks had much more casting variances than new motors, but in the end , you'll never know till u check. If your input shaft isn't ultra tight and has normal movement, that will alleviate trouble too. Good luck- let us know.
Yes I'm sure your right with that ^ , and my input shaft play is withing spec so I'm confident. It's just one of those things you don't want to happen then beat yourself up for, I think it's going to be ok. Once the damn bushing comes in I'll update the thread.
You'll likely be fine. Just to be clear, I meant radial play, not end play. Be careful and make sure you get a true bronze bush. The bronze bushes are usually oil impregnated and will survive the ride the longest. Most new bushes are Chinese crap and dark in color. If a magnet sticks to it, stay away from it. If you end up with a true bronze unit, a tiny bit of high end grease is a good idea.
Good luck to you. I would never touch anything mcleod, never again. I had two of their twins and both blew up within 500 miles or so. Both were way out of balance.
They were not accommodating and it cost lots of $$$$ to clean up. They were good many years ago prior to big buy out.
Look it over closely, especially if you know what to look for.
I'll see if I can find a link on the true street twin.
http://www.mcleodracing.com/index.php/clutch-kits.html
Here it is Jon, scroll to the bottom of the page. Handles up to 1200 hp. It's nearly twice the cost of rst line.
To piggy back on what you said- I know your pain, traffic stinks here as well, especially on the west side. It's part of big city life. You could get lots of relief if you get the rst organic discs. They don't get so sticky when hot. Heavier flywheel helps too. I'm at 30 lbs on my assembly but i have a hybrid disc which helps.
