Moser M9 GTO Package
http://shop.brutespeed.com/Moser-M9H...er-M9HPGTO.htm
Eliminate the problems with the weak rear in these cars, this package replaces the entire IRS rear assembly with a Moser fabricated 9 inch. This package comes complete with everything needed. Take a look at the above link. There is a link to the installation instructions at the above link, so you can see how it is assembled. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
The more I look at this kit, the more it looks like one of the better 9" options out there-minus loosing the IRS part. I assume there's plenty of room for adjusting angles n stuff. Options are endless with the 9" housing.
The OEM diff has proven itself to hold up to twice, almost three times it's original capacity rating, I wouldn't say it's a weak piece; I feel that's a little misleading. All my higher end diff builds are still intact and have no failures even at the 700+ mark. The only failures I've recorded has been on trutrac carrier builds. The trutrac doesn't do so well in the GTO
No 12 bolt options. Overall the nine inch is a much stronger rear than the 12 bolt. That car did get mini tubbed, and the rear was narrowed. Thanks. Bob
__________________
You are correct, there is plenty of adjustment to this rear. Thanks. Bob
__________________
It's basically the same rear I had in my Camaro. Bob
__________________
__________________
Bump for a great deal. Bob
__________________
It says on the Moser instructions that the fuel tank has to be removed and a fuel cell installed. It doesn't look like the floor has been cut out that I can tell? A guy from Moser said it was for clearance, but couldn't tell me what they did to the floor. Do you know? Buying another fuel tank, pump and accessories is not a small deal.
__________________
Bump for a great rear! Bob
__________________
