When to up grade half shafts and D.S.?
Originally Posted by Mike2002
Like the title says. At what point will the stock parts fail. Would i need these if i get a super charger?
TIA
mike
TIA
mike
LS1Tech Premium Sponsor
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
TIA
mike
TIA
mike
![Bomb](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_bomb.gif)
Originally Posted by BMR Fabrication Inc.
We replaced ours before it failed but the guys over in Australia seem to have problems once they dip into the 11's. Usually the first failure is either one of the rubber joints on the driveshaft or the inner CV joint on the rear axles. Once both of these are upgraded, you can run into the 10's without much problem. If your 60 ft/times get below 1.6, you will probably want to upgrade the inner stub axles also. Those are next on the failure list ![Bomb](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_bomb.gif)
wow, 1.46 60ft
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
Originally Posted by horsepower
wow, 1.46 60ft
what tires / wheels do you have squeezed onto that thing?
