NEW GTO Driveshafts available!
LS1Tech Premium Sponsor
We now have a larger selection of driveshafts to choose from for your Goat. After receiving various requests, we now offer aluminum and carbon fiber shafts for varying power levels and budgets. More information and pricing at: http://www.bmrfabrication.com/GTO.htm
I will be out of town until the 24th an unable to view this forum, please email your tech questions to Frank at Tech-help@BmrFabrication.com or call 813-986-9302.
Great writeup about the driveshafts. What about those of us who have purchased your old style driveshaft. Which one is that? I thought it was chromoly or was I mistaken? What are the HP and rpm ratings of your old driveshaft which used to be the only one available?
The following is info from the site.
"At 130 mph in 3rd gear, an automatic car will be at 5800 rpm. This is the same rpm the driveshaft is spinning however in overdrive at the same mph, engine rpm goes down but driveshaft rpm goes up to 6200 rpm."
This is not true the drive shaft speed is dependant entierly on the speed of the rear tires. The drive shaft speed is 3.46 times greater than the half shaft speed. Shifting to overdrive unless you are spinning the tires on the shift will not result in a higher drive shaft speed for a given vehicle speed. There for a 3.46:1 rear ratio car should be able to go 143 mpg with the 3.0 inch steel shaft and 138 with the 3.0 inch aluminum shaft.
Also I would like to know how you calculate the critical speed of the drive shaft.
I would also like to say that your product looks to be very hight quality, and I plan on purchasing a shaft in the near future. I just want to be an informed consumer.
Originally Posted by Greg04GOAT
Some information is incorrect on the BMR web site about the drive shaft speed.
Nope, driveshaft is spinning faster than half shafts. one rotation of the half shafts for every 3.46 rotations of the driveshaft. That is why when you go numerically higher in gears the engine has to spin more rpm to make the car go the same speed. because it takes more rotations of the driveshaft to turn the halfshaft's once.
