best cam
best cam
ok peaple i need your help, dont know much on performance, 2004 air intake changed, wires,plugs, throttle body, rwtd predator custom tune. putting headers on soon. putting asp underive pulley on soon and want to do a cam job just cam nothing else. what cam is the best and the ratio example 220/221 please clearly tell me and witch one. thanks
That is like asking which tire is best to go fast on... It depends really on the use of the vehicle, powerband you want, how big your plans are later, if you plan on headwork or valvetrain upgrades, etc. I'm sure a few can chime in and say what their numbers were with specific cams but if you prefer more top end or more torque or whatever, it is all about what you want to gain.
Best bet would be to contact one of the cam companies (crane, comp, lunati, etc.) and tell them what you want. They should be able to give you some solid recommendations. Compare the results you get, and then make the call.
It is always a give and take situation. I think a really big cam in a GTO is kinda stupid, but to each his own. If it was me, I would probably go no bigger than a 224/224 on 114 with street style lobes, but there are profiles that will get you a lot more power.
I really agree with all of you guys about what you said . I have tried a lot of cams on the lumina ss (GTO) starting with the small one`s to the biggest . However , we didn`t like that kind of huge cams on it . Although we find out that ( TSP Custom 224R Cam: 224/224, .581"/.581", 114 LSA ) was the best choice for our GTO .It was in the middle in my opinion ,especially tha we combine great high rpm between cam and the ls6 . Our car dyno was 407 HP with the same parts you mentioned except for 3.46 gears , HPtuners and MT radials. We passed the 1/4 mile at 12.4 ... I dont remmember trap speed... any way we are going for a stall and some suspension , seeking 12.0 or high 11`s
see ya.
see ya.
I would personally go with a 224/224 .56x/.56x on a 112 ( i like lope). the same cam on a 114 will make a little less torque down low and peak about 200 RPM higher.
eric about cam
thanks gents, i will only do a cam job. nothing done to the head. just cam, yes im changeing my exhust and putting headers on it. i have a custom tune by rwtd now and a redo when done. i have new tgk plugs, tayolr wires.
ported throotle body and a cold air intake kit on there. so i want more horse power more torque. and thats what i have on my 04 a4 gto. so please send me more info, best cam. not really worried about the dealer nowing because i got some one works there. so i will get my warranty inanyways. thanks
You'll be having a lot more fun with yours than I will mine- for a couple for years anyway!
Cory
Your upgrades are cool man I wish u a good luck and take your time choosing the right cam , and I advice u to do more research before u go for any decission . And as CHARRIS mentioned (That opens the door very wide to a whole array of modifications ). I really agree with him .
see ya.
see ya.
see ya.
see ya.
Ya guys stock heads and no converter , My next setup well be converter , some suspension and weight reduce , and also some spray .. 100 shot . We well try to post the videos as soon we can to prove it
bye.
bye.
