Free AEM Brute Force Intake
Hello Everyone,
It's that time again. AEM is looking for a 2005 Pontiac GTO for intake system development. The vehicle must be located in the Los Angeles Area, and must have the stock intake. Testing should take no longer then 2 weeks and transportation arrangements can be made if necessary. In exchange for your assistance AEM will provide you with a free AEM intake system. AEM is fully insured and while your vehicle is in our possession it is fully protected. Information on AEM can be found on our web site at: www.aempower.com Please e-mail any responses or questions to jgleason@aempower.com
Thank You
Jon
Thank You
Jon
Hmm, AEM cold air intakes for GTO's? Strange... So will this be a true cold air intake and route the intake tube to somewhere other than in place of the factory airbox?
As for the stand alone EMS, I am not sure if and when we will be making one. We have a lot of new applications on the table and I know the LS1 has been brought up, but the powers that be are having a hard time deciding if we should produce one. Keep checking the web site and hopefully it will be on there soon.
Thanks
Jon
Can I order one of these heat shields to fit my 05 without ordering the whole intake? (once one has been designed to fit of course)
Ah thats fine... See if you can find a way to shield the MAF on the 05's because when that thing heats up the IAT sensor reads the heatsoaked temp of the plastic and not the actual airflow temp going through the MAF. Since it is part of the MAF and not its own sensor like on 04's, it cannot be relocated. (saddly) So if you guys find a way to stuff the MAF on the cold side of the heat shield, that'd be a big improvement over anything else.
Originally Posted by Jfulcher
You can also drill a hole in the K&N and put it there.. That's how my kit is..
