Now taking pre-orders for the LS2 Predator programmers!
TBYRNE Motorsports is now taking pre-orders for the LS2 Predator programmers. Diablo expects to have them ready to start shipping in a few weeks so this will allow you to receive one of the first that is released.
The Predator is a state-of-the art high performance tuning flash programmer, which advances the timing, optimizes the air/fuel ratio and remaps the transmission shift points (in automatic transmissions). Unlike other 'tuners', DiabloSport’s programming is performed in very small increments throughout the entire RPM range, for a smoother, wider and a more predictable power delivery.
This unit has taken the hand-held programmer to a new level. You will notice quicker acceleration and better throttle response. If you have an automatic transmission, the Predator will also give you a firmer, more responsive shift pattern (gas vehicles only at this time). The Predator will raise your rev limiter as well as it allows you to raise your top end speed limiter if you have installed high speed rated tires.
A unique feature of the Predator is that is allows you, the user, to “fine tune” DiabloSports program. Since vehicles are located at different elevations or different weather climates, the way the vehicle responds to the DiabloSport program may vary (not all vehicles are exactly alike). Some vehicles will see better gains than others and some may see better (or worse) gains than advertised. This is due to the fact that not all vehicles respond exactly the same. Now, here’s the good news…If you're not totally satisfied with the way DiabloSport program performs, the Predator allows you to make your own adjustments to the program. For example: If you feel that the shift points are too firm, you can go into the program and lower the transmission line pressure (gas vehicles). If you feel that you can benefit from a higher shift point rpm, you can go into the program and raise shift points. If you feel that you will benefit from a few more degrees of ignition timing, you can go into the program and add some timing (gas vehicles). The Predator allows you to "fine tune" the DiabloSport program to meet your specific requirements.
The Predator has diagnostic abilities near identical to GM’s Tech2 software. The predator will allow you to read diagnostic trouble codes (DTC), erase DTC’s and perform live data monitoring. You can monitor your engine sensors while driving your vehicle and much more.
Part number and pricing is -
U7191 2005 GTO/C6 Predator programmer with overnight shipping $399.99
Orders can be placed online or by calling 1-877-4-TBYRNE (1-877-482-9763).
ORDER LINE - 1-877-4-TBYRNE (1-508-636-0770 in MA)
E-MAIL - tbyrne@tbyrnemotorsports.com
NEW WEEKLY SPECIALS CAN BE SEEN ON - OUR WEBSITE
A few details from Diablo -
The New #U7191 DiabloSport Predator for GM LS2 applications is currently in the tuning stage of development. All testing and development is being done exclusively at DiabloSport Performance Tuning, our Delray Beach, Florida facility.
Our newest Predator for GM will be a little different then past GM Predators.
Predator was the first stand alone hand held flash programmer for GM to offer end user adjustability, advanced diagnostics with read and erase fault code capability and live data monitoring.
The New #U7191 Predator will be the first to offer not just great dyno tested pre-programmed performance tunes, but the ability to hold multiple custom calibrations, and for the first time in the GM flash programmer market a stand alone flash programmer to allow end users to do real time data logging, through the Predator by itself, or through your PC or lap top with a free software download for the diablosport website.
Now with Predator you can flash your LS2 vehicle, make fine tuning adjustments, from real time data streamed from the vehicle, with out the need for a clumsy and expensive laptop. The ability to get custom calibrations from a nation wide network of DiabloSport CMR custom tuning dealers, done live on the dyno, or through simple E-mail. The DiabloSport dealer locator can help find a dealer near you.
http://www.diablosport.com/OurDealers.php
If the idea of having to learn to tune, buying an expensive full blown software program seems a little intimidating, we have the answer, and the adjustment to allow for a safe range of tuning changes to be made, along with speedo re-cal, extended limiters and all the other great features Predator is known for.
No need to send your valuable PCM out to have programs loaded, no down time on your vehicle, no paying all the freight and taking risks on lost or stolen parcels. With Predator in hand you always have the ability to restore your stock calibration for trips to your dealer for warranty work.
For the money DiabloSport offers a true “flash tool”, not just a flash.
Nice!!!!!
1) Vehicles Wanted for Beta Testing
Do you want to be on the cutting edge of performance?
Do you want to have the latest technology before any one else?
Then you want to get into DiabloSport's Beta Testing Program!
If you have one of the vehicles below and live or are going to be in the Delray Beach, Florida vicinity.
Please email us
I just live 20 min south of delray!
Please email us
Predator tunes re-map the:
Fuel Curves
Timing Curves
Torque Management
Extend Speed Limiters
Extend Rev Limiters
Disable CAGS (Skip Shift)
Part and Full Throttle Shift Points
Shift Timing
Shift Presure
DiabloSport Performance tunes require the use of Super Unleaded / Premium grade fuel only, like carried by Amoco/BP, Sunoco or Mobil
Fuel Curves
Timing Curves
Torque Management
Extend Rev Limiters
Shift Timing
Shift Presure
The Predator allows the end user to adjust the following parameters:
Timing Table 2000-4000rpm (+15/- 20%)
Timing Table 4000-7000rpm (+15/- 20%)
Fuel Table 2000-4000rpm (+/- 20%)
Fuel Table 4000-7000rpm (+/- 20%)
Idle (+ 500rpm / -300rpm)
Speed Limiters (Trucks Only)
Rev Limiters
RPM Shift Points
MPH Up and Downshifts
Shift Timing
Shift Pressure
Cooling Fan ON and OFF temperatures
Re-Calibrate Speedometer for Gear and Tire Size Changes
Torque Management ON/OFF adjustment
Torque Management abuse mode time limit ON/OFF
% torque reduction vs. RPM ON/OFF
Upshift torque reduction (all gears) ON/OFF
Injector Adjustment
Adjust for different injector size
Adjust for long term fuel trims
Catalytic Overtemp protection Adjustement
Disable P0430 and P0430 codes
Adjust COT enable temperature
Multiple Misfire P0300 adjustement
Misfire Low rev
Misfire Low cyl
Misfire idle cyl
EGR disable
Enable/disable MPH, set high to disable
Disable P-codes: 0400,0401,0402, 0405, 1404 and 1409
AIR code disable
Disable P-codes: 0410, 0412 and 0418
Rear 02 disable code
Disable P-codes: 0137, 0138, 0140, 0141, 0157, 0158, 0160 and 0161
Transmission functions do not apply to trucks with the Allison transmission.
Rev Limiters
RPM Shift Points
Shift Timing
Shift Pressure
Injector Adjustment
Misfire Low rev
Misfire Low cyl
Misfire idle cyl
EGR disable
AIR code disable
Looks like they will be taking care of the torque management. That's to be expected in a way. One of the major programming "issues" that most people want to take care of.
