ls7 goat?
The price for the Warhawk is right there with the LS7 so why not? Plus down the road I may want to swap out this power plant into something else. It might be better to go all out now then to have to do it all over again.
I've also looked into the LS2 combos. They aren't totally ruled out at this time. I inquired about the ETP LS7 heads but haven't received a reply.
It may be on par with the LS7 block, but it'll still be more than a sleeved LS2 block (which is stronger than the LS7).
Last i read the warhawk was still a ways off.
Originally Posted by 05_GTO
The LS7 is not worth the money, you can build something much better with how much they charge you for a LS7 IMO.
15K is a lot of money for just an engine. you could put money into the motor and some suspension stuff along with new rear gears and kazz LSD, and still have moeny left over and beat a LS7
Originally Posted by 05gto60
so saying you have an LS7 is worth more than saving money AND being able to beat an LS7?
The drivability/reliability of an LS7/T56 setup would be awesome. Is it the cheapest way to make 500hp? Of course not. But you have to think about more than $/hp sometimes.
And yes, bragging rights would be cool too.
they are less reliable than big CID LS1/2 solutions...
buying an LS7 is for one reason...so you can say "its got a LS7 in it"
Originally Posted by ram09
That and the LS-7 is built to handle at least 500 hp from the factory and the LS-2 only had 400 hp.
