I Want More Power..
I Want More Power..
Guys... see my mods in Sig.
1- do you think i should change my Dif to 3.74?
2- I need to go for CAMs... i dont really know much 'bout it.. n my car is runing on Auto.
3- I'm using 19" tiers... and i want to drop the car down.. but it's touching the fender... any idea of what can i do??
3.73's are best for a mainly street driven auto. I wouldn't go higher. I personally did 3.91's, but I have an m-6.
A cam will maximise your intake charge, and exhaust expelsion. It would be a good idea to aid your blower with a cam. I am going Harrop HH 122 intercooled blower, and adding a cam at the same time. Just makes more sence to me.
To me 19" tires/rims are just too big. 18's are OK, but racing should be 17" or less.
All just my honest opinion.
^^^^thats good advice!
I've not heard of anyone with a gTO getting 373's (or 374)
3.91:1 is the popular gear in australia,
I think they say in 6th @ 80mph you will gain like 400rpm
so you will still be below 2500rpm
there are some who have gone with 4.11 or 4.10
but I think that would kill your drivability
you only have one (1) Cam
it's in the middle (Pushrod engine)
and a new one (with springs and pushrods) will make a big difference
I would go with the MSIV (Magic Stick 4)
but I don't know how that will do with your supercharger
good luck
what's the best brand i can go for Diffs... ??
the problem here in Dubai is that we can't get parts easily.. And there are not much of sites that can ship it 'till here... I've been looking for the Goat Center gauges pod for a month now.. and i can't find it... it's really irritating me... I need lots of thing for my car but I can’t find it...
the most popular is 3.73 for the auto
and 3.91 for the 6 speed...
those are the two best options you have...
I don’t want to go for 4.10s too much traction loss... besides, we need top-end in here.. we have great open high ways..
I guess I’ll be looking for 3.73s... it’s a bit hard to find though...
Do you guys know any website to order it from??!
<<<< did that....
<<<< did that....
Harrop makes a bolt in 12 bolt that reuses your stock stubs and axles. Only that way can you get 4:10-4:11. The 3:91's are the highest you will get. 3:08 is the lowest.
Difftechnics will be your source for the new GTO gears.
Talk to Ed @ Flowtech Inductions. He can set you up with a really nice FI cam. You should expect a gain of at least 45-50 RWHP.
JHP makes those center mount guages.
With the blower and you saying you want to do top end runs on the highways there i'd stick with the stock diff and gears. You aren't going to gain anything noticeable going from a 3.46 to a 3.73. As for the cam, comp xe-r 228/232 114 lsa.
If you really want to make that auto move i'd get a higher stall torque converter if you don't already have one. i'd recommend something in the 3200 rpm range for a heavy car making lots of low end torque.
45-50 rwhp??? isn't that alot ?? i though it would give me more TRQ.. and it wont be morthan 25-30... that's all... I don't think Cams is what i'm looking for now... i'll leave it for later..
do you thing if i got more Boost (10 psi) my eng. and gear will handel it??
