anyone here running faster than 11.49?
I'm looking for some GTO cage info...
any info would be great.
who made it?
who installed it?
how much was it? how much was the install?
did you completely loose the use of the back seat?
does it get in the way of driving the car (on the street)?
any regrets?
Russ
who made it?
who installed it?
any regrets?
Russ
you are going with the swing out door bars right? they are still legal to 8.50.
is this a mild steel or chrome molly cage? i would spend the extra cash and go chrome molly, plus it's easier to tig weld and still protect the interior.
i wouldn't worry about the rear bar (unless you have kids)
mine are swing outs, yet remove one bolt and they come right out.
is the cage "custom" or a kit?
iv'e got a buddys stolen gto "stripped" to use as a mock up for the cage kit i want to build. nice and tight and hidden!
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
Check out WavyDavy's cage on LS1GTO.com
I think its in the Southeast section. His rear bar is removable, but made in such a way that it doesn't look like it would be and has passed visual inspection at the track a number of times.
http://www.ls2gto.com/forums/showthread.php?t=131058
Originally Posted by KrautBurner
still can't believe that there's only like 3 or 4 gto's with cages,
yet there's over 20 that run low 11's or faster
It is hard to believe there only are a few GTOs with cages, however not hard to believe those of us running a low pass once in a while don't put cages in our cars. I plan to run almost exactly one 10 second pass with nitrous and a few changes made. Until then it's just a nice car that CAN run a cage required pass if need be. I've been running on motor with low 12 second passes just for fun, with gears now 11 seconds motor hopefully, fast enough for me. From what I've seen most IHRA tracks dont hastle you until you hit 10s.
