Road Racing Road Course | Autocross
What should I do to increase high-speed stability (Autobahn driving)
Old 01-13-2010, 04:30 PM
Schantin's Avatar
Default What should I do to increase high-speed stability (Autobahn driving)
This seemed like the best forum for the Q.
Moving to Germany this summer. Brining my Camaro. Car runs great but even at the track will start to feel a bit "unstable" (ie, the front begins to lift a bit and feel very light) at about 130mph.
I'm looking to reliably run the car to 150-160MPH without worries. Current suspension consists of UMI subframes, UMI LCA's, front stut brace, and panhard, UMI chassis-mount torque arm, and a Moser 9" w/ BMR drop brackets for the LCA's (currently set in the "mid" position). Springs and shocks are still stock.
Brakes are covered.... Baer Eradispeeds w/ Hawk pads and Earls lines + Sumitomo Y-rated rubber.
So....$0.02 appreciated. Not sure if different springs/shocks will increase stability....or if more is needed to prevent the car from lifting at high speed (like smoothed paneling under the car, splitters on the front bumper, etc.)
Old 01-14-2010, 07:27 AM
OUTLAWZ RACING's Avatar
Coil overs are your friend, New bushings all the way around. Also look into some better tire with a super high heat rating aswell. I bought a set a michilen pilots while i was there they where no us spec but the work great. You dont have the ss hood so your good there the air dam is fine also. You can drop the car also the autobhan is smooth lol. I like autobhan 5 for long wot blast and autobhan 3 for twisties headed towards hammleburg lol.
Old 01-14-2010, 11:46 AM
SIK02SS's Avatar
springs/shocks will help, as will an alignment to get the 'lift' feeling to go away. adding a smooth panel under the front will only increase actual lift, you would want a splitter to keep the nose down, not a belly pan
Old 01-14-2010, 02:25 PM
roy
roy's Avatar
I have no concerns running up tp 190mph on the Autobahn.
Baer Eradisspeeds and Hawk pads won't take too much beating before they give out.
Once the rotors and pads are junk , switch to some brembo blanks and Ferodo 2500 pads or equivilent compound.
Fast camaro owners over here have Brembo front brake setup and Koni shocks and higher rate springs, bigger sway bars and semi slicks.
Old 01-14-2010, 05:37 PM
Schantin's Avatar
Thanks for the info to all who responded
Old 01-14-2010, 05:54 PM
baalic's Avatar
+1 on the Splitter for the front especially with it lowered, it will help stop the air from going under the car and giving you the floaty feeling... Also at those speeds our Spoilers actually start doing something other then for looks, if you don't already have an SS spoiler maybe opt for one, it may give you a tad more downforce, or heck maybe not I'm not sure which adds more, I would just assume the SS spoiler...
Old 01-15-2010, 02:04 AM
roy
roy's Avatar
Splitter not necessary.
Old 01-15-2010, 08:13 AM
JD_AMG's Avatar
Before reading any of that my first guess was you were on stock shocks.
Throw some Konis on there and you will be amazed, its a whole new car. No longer floating, bouncing, or having a disconnected feel. Makes the car feel like 1 whole piece instead of separate front and rear. Dramatically increased handling and better ride quality as well.
http://www.stranoparts.com/partdetai...D=20&ModelID=7
Old 01-16-2010, 03:53 PM
NJSPDER's Avatar
At high speed alignment is critical. As long as you have good bushings and shocks, nothing will make as much difference in performance as a proper alignment.
-Tim
Old 01-16-2010, 11:25 PM
NataSS Inc's Avatar
When you get serious about it, let me know.
Old 01-17-2010, 12:26 AM
roy
roy's Avatar
Nata, I believe there is vast difference between what some people would call serious.
Old 01-17-2010, 12:55 AM
NataSS Inc's Avatar
True, but there is a difference between going fast and going fast properly. My serious might be more on the outside of the envelope than others but it still applies.
Old 01-18-2010, 12:31 PM
kidreno_21's Avatar
OP - I am moving to Schweinfurt, GER end of Feb this year and I am bringing my SS. I have done some research on this, main thing I am concerned about is the minimum ride height (11cm for the lowest point under the car) and max dB at idle and at 3k rpm - 95dB.
Where are you off to?
Old 01-18-2010, 12:32 PM
kidreno_21's Avatar
subscribed.
Old 01-18-2010, 01:14 PM
SIK02SS's Avatar
the RK large 3 piece or Freedom spoiler will do more, but none are needed..
I agree. You really don't need to reinvent the wheel for this. People are already doing it, take there advice and consider anything else as an extra or new mod
Old 01-18-2010, 11:48 PM
NataSS Inc's Avatar
Ok, before you get alot of bum scoop on this, let me interject.
Splitter, not nessacary in any way shape form or fashion. Great for the track but not good on the open road. Creates way to much down force on the nose.
Big tails, spoilers etc: dont need them. I ran the LG SCCA spoiler for a few events and I noticed over 150mph it put WAY to much drag on the car and would actually lift the nose a little bit. That is NOT ok at speed.
If you want a great adjustable spoiler, contact Alan Blaine at Blaine fabrication and ask for his ORR adjustable lexan spoiler. But if you dont do that, leave yours as is.
You want a the biggest front sway bar you can get your hands on. And leave the factory one on the rear.
Suspension, go with Koni's on all 4 corners. they are the best thing for both street and track driving. Coil overs would be a bit of over kill ( I ran the LG coil overs and though they were awesome, they cost an arm and a leg and on regular roads you could feel every bump).
Alignment is KEY. You want as much Castor as you can get, this greatly increases your high speed stability (I think on my car the most I could get was about *6). This will slow down your "turn in" so its not a "track set up". go with about 1/8 camber and 1/16 TOE IN! Toe out is only good on a race track, NOT on the open road at speed. You dont want a **** ton of camber because you will wear the crap out of the edges of your tires and a blow out at 160+ isnt any fun.....ask me how i know.....I had one @ 204mph. Took out the left rear of the car.
TIRES TIRES TIRES....You wantthe highest speeds rated tires you can afford. Having a tire de-skin itself at speed can cause all kinds of hell at speed. We had one seperate just enough to cause the car to yank hard to the right and the rubber didnt even come off the tire itself. That "1 rise it gave the left side was enough to almost push us off the road. AND INSPECT YOUR TIRES EVERY CHANCE YOU GET BEFORE MAKING A PUSH ON THE ROAD.
If you are running an A4, you will definately want to look into a trans cooler. You will also want to look at a diff cooler for those times you know you are going to push it on the autobahn. If not, be prepared to be changing both of those fluids frequently.
Those are just the starters. when you really want to start pushing some speed, you have to start looking at the entire aero package, making the car slicker, air dams etc.
Autobahn driving isnt anything like driving on US highways. Thier highways are maintained at a level that the US couldnt even imagine. Given the racing i was doing i could get away with factory brakes. Out on the Autobahn, I would suggest a big brake package upgrade. Getting on the binders at 160mph+ will test to see how water tight your *** is and chances are if your not on top of things RFN it could cause major issues.
Any questions, feel free to ask. I have more time over 200mph than 99.999999999999999999% of the human population.
Old 01-19-2010, 04:24 PM
Schantin's Avatar
Thanks for the great information. I'll start pricing Koni's and a new front sway bar for April (when I'm shipping the car.) I'm thinking I might wait till I get to Germany for the alignment.... hate to get it dialed in and then the people at the VPC hit a pot-hole or something to mess the new alignment up.
Appreciate the input on tires too. I'm currently running Sumitomo HTR ZIII's (Y-rated) on 17" wheels. Guessing they are "middle of the road" as far as tire/performance. I also have a set of MTR Drag radials...but I'm not a fan of running those on the street.
BTW, my cars an M6...so I should be fine w/out a cooler.
I might very well be over the 95dB sound barrier. The car is a H/C car with LT's and a GMMG exhaust. Not very quiet. It does have stainless cats, but I'm glad you mentioned this.....as I might need to add something to tone it down a couple notches. I'm good on ride height..... everythings snugged up against the body for max clearance (a product of getting sick and tired of hitting my exhaust on every bump when I had an STS on the car) .
BTW, I'm heading to K-town (Landstuhl).
Old 02-06-2010, 01:54 PM
Trunion King
bene's Avatar
GL with your car shipment. I'm glad UK isn't as strict as Germany. I'll be planning a trip over there though with my camaro to do a couple of laps in Nurburgring. I know the locals are crazy in autobahn... I've seen some pinto looking car doing 120+ MPH.
Old 03-02-2010, 09:33 AM
Y2K WS6's Avatar
Very cool thread.
Out of curiosity, what does it cost to get a car to Germany?
NATA SS I've been discussing it with a friend, What does it take to get a WS6 trans am over 200 MPH reliably. I'm planning a set of 3:50 rear end gears, and about 700 HP to the rears. my suspension, brakes, etc are all squared away. (koni's strano's etc.)
Old 03-02-2010, 09:38 AM
Y2K WS6's Avatar
Very cool thread.
Quick Reply: What should I do to increase high-speed stability (Autobahn driving)
