I think I got a good start, have some questions....
i didn't look at the car in question, but SS brake lines and good brake fluid would be a great start. If after your first track day you see something on your rotors that looks like it's smeared on there, then get some better pads more suited for track temps. Until then, don't worry about them
https://ls1tech.com/forums/vehicle-c...rano-more.html
I talked to him and he said it was, in fact his fault this happened with the brakes.
Any heads up from you guys looking at what I bought for a car as to what it needs to HPDE?
Seats? Do I NEED seats? If so will a Trans Am seat work well with a harness bar and some belts? I know when I get better I will need seats so I am not fighting to stay in the seat....but do I need them right now?
How do I put good belts in the car AND keep the stock belts?
If I DO decide to HPDE it with the stock brakes, what pads, brake lines and fluid do I need?
My Buddy with the red SS, we put a special baffle in his oil pan when we built the engine at my house...do I need that yet? Or do I need to overfill the oil 1/2 a quart for insurance?
Power steering cooler, do I need one? Or a turn one pump or nothing yet?
I know all of you have been down this road...my ears are WIDE open and listening.
I know I ask alot of questions LOL, dont want to make dumb moves if I can avoid them.
Please look at the link and lemme know what you think.
btw, i'm 6'3 175lbs and fit in my 2002 camaro with a helmet on in a more vertical seating position (as you would want on track). I have an old LG harness bar with G-Force 5 point harnesses and the lap belts are using the same bolts as my factory seat belts are on (had to widen the harness holes a little so the bolt fits through), the shoulder harness wraps around the harness bar and until i put a race seat in i dont use the submarine belt
like I said, all you need (which really you don't need, but it's a safety item imo) is SS brake lines and a decent fluid, like ATE Super Blue or Motul RBF 600. keep those tires, pads, etc and just run her and get seat time. when you start notice something that looks like it's smearing on your rotors, then its time for new pads
You wanna sell that harness bar? Anyone else make one for these cars?
EDIT, do I need a strut tower brace?
10-4 on the other, leave the car be for now.
FRRAX isn't a road racing autocross social network.
The information you seek has more than likely been dissected and discussed.
You won't be spoon fed. There are some expectations that if you have an issue, you do the work to find it.
It's not corner-carvers.com by any stretch. But it isn't 4chan either.
think about your inseam vs. shirt size if youre not sure how youre built. you will also find that youll need to put your seat back up straighter on a road course then any other time.
a STB or SFC will NOT HURT anything. i dont give a damn what anyone says, tieing the subframes together is a good idea and safer for the life of the car. ive noticed less creaks since doing it, and my car only had 24K miles when the SFC were installed.
your height is irrelevant. you can be all leg or all torso, either of which will impact your seating position. im 6'1 and have a long torso. with an arizen racing seat and my helmet on, my head hit the t-top. i had to get the brackets custom lowered just to fit in my car.
I see what your saying on your "build" type LOL.
