Suspension setup assistance please
Current mods: KYB adjustable shocks, H&R lowering springs, welded subframe connectors, poly/rod end panhard bar, poly/rod end LCA's, LCA relocation brackets, Im currently boxing the stock panhard support bar, also Im cutting out the stock rear spring mounts and welding in some adjustable spring cups.
Other than that search on here, seriously these kind of things have been covered so many times. The first obvious thing, and most common thing you will hear is seat time. But good general setup advice would be to steer clear of any drag parts (like non-gas charged drag shocks like QA1s, Afco, Strange etc.), oversized drag swaybars, poly suspension pieces, short torque arm, heavier rear end, etc.
Good shocks are a must, koni sports, race bilstiens, KW coilovers etc, will make a huge difference. Strano springs or your own custom springs from ground control with a coil-over sleeve for the front shocks. Strano or UMI swaybars (35mm/22mm). Fays2 watts link definitely makes a difference, rear is more planted and stable. Good quality blank or slotted (not drilled) rotors with good pads (pad compound will depend on what you are doing, auto-x will be different then higher speed road racing).
What I am looking for honestly the tips/tricks to get some forwards bite. Honestly I loose traction quick through 1,2,&3 gears. I have a lot of previous racing experience, but setting up a full tube chassis car as compared to a modified street car is a BIG difference.
Currently i have a stock torque arm (havent decided on aftermarket setup yet, inputs welcome please) also I havent put the car on an alignement machine to get the actual degrees. I'm making the assumption that its just within stock specs, because I have dont have any tire wear issues or pushing/pulling through the turns.
