Road Racing Road Course | Autocross
4th Gen drift build
Old Oct 13, 2013 | 09:15 PM
  #121
Sporty-X's Avatar
can you use this kit also for everyday use or not ? i pm you an adress too for a quote shipped to my place. Thanks
Old Oct 13, 2013 | 09:24 PM
  #122
Sporty-X's Avatar
i have also others questions :
1) have you done a completely separate system (with separated brake discs) for your hydraulic e-brake ? Don't you beleive the e-brake can be simply connected to the rear existing calipers ?
2) how do you deal with caster and camber on the car ? keep them stock or is there a need of having upper adjustable A-arms
3) i have adjustable torque arm and relocation brackets on rear end (there were set for drag racing) : should i change the adjustment of the TA ? any suggestion for angle ? The relocation brackets are not any kind of difficulties because my car understeer a lot and it is tricky to make it slide
Old Oct 14, 2013 | 06:57 AM
  #123
Jenson's Avatar
Sporty, you can drive on them daily. It takes some getting used to as the turn in is magnified a lot. Of course with your front end setup properly for drifting, you'll eat through some front tires really fast. I can make the brackets with less angle than the set pictured. The two piece version can be made with 66* of angle or 45*. 45* is what I had with the cut uprights. Works good and doesnt require super crazy offset wheels. I also daily drove on that setup for a year+
Yes, I have a hydro e brake system minus the calipers and lines. Making a custom handle for a guy now. It's a separate system from your brakes, much more reliable and more safe to run you E brake like this. It's actually required to run like that per FD rules now.
I have adjustable upper and lower front A arms for camber/caster/toe. Once I get everything setup and running I'll start messing around with the rear end to add a little more camber too.
I'd start with 0 on the pinion angle. The relo brackets should help traction, these would be needed once your car is dialed in and not making rear bite. As in you add throttle and the car wants to continue rotating and not go forward. If you have -2, plus the relo brackets, a soft front setup, and soft rear tires you will induce some under steer.
What shocks are you running? Spring rates? Sway bars?
Old Oct 15, 2013 | 12:51 AM
  #124
Sporty-X's Avatar
about the steering bracket : the 45 is probably the best choice for a car also use as a daily driver. What is the stock steering angle ?
i will probably do some brackets to use some C5 rear calipers i already have with a hydrau e-brake i already have too. I just wondered if it was necessary to make a separated system as many people here just connect their e-brake to the existing rear calipers
what is the model of A-arms are you using ? any suggestion ?
I use Bilstein HD shocks, stock springs, and Hochkiss sway bar (Front 1 7/16 in./Rear 1 in)
Any suggestion of modification is welcome (springs ?). Is there a need of lowering the car ? I don't want to compromise too much using it as a DD too.
Old Oct 15, 2013 | 06:37 AM
  #125
Jenson's Avatar
Stock is steering angle 30* total
When you connect it to the existing system, it can cause issues if you try to use both at the same time. IE: about to crash in to someone, pull the handbrake mash the foot brake and the fluid isnt there. If you do do it that way get a manual prop valve to give the system a chance. You'll also need to delete the ABS module.
I'm using all Spohn front A arms, they have the most clearance and best joint design imo.
Ditch the stock springs and get a set of strano's or eibach pro line. They are both very similar in rates, the pro line would be a little more street friendly. Definitely lower it, will help a ton. These things are like 4x4's on the soft factory springs. Heck, I have the set of springs from my car now that I think about it...somewhere.
Old Oct 15, 2013 | 12:09 PM
  #126
Storm Trooper's Avatar
WHERE ARE THE SIDEWAYS PICS?! lol jk, thats really badass, looking forward to seeing it done.
Old Oct 15, 2013 | 01:32 PM
  #127
Jenson's Avatar
I know right!! This is taking FOR-EHVR...FOR-EHVR...FOR-EHVR
Old Oct 15, 2013 | 03:30 PM
  #128
Sporty-X's Avatar
this saturday
Attached Thumbnails 4th Gen drift build-551016_10202009709061772_1262515043_n.jpg
Old Oct 15, 2013 | 06:01 PM
  #129
NnOoSsSs's Avatar
Awesome man cant wait to see more progress
Old Oct 16, 2013 | 07:43 AM
  #130
camarokid91's Avatar
Are you going to heat up your rearend and cool it rapidly on the top or are you going to cut the rearend tubes partially and re-weld them? I hear the rearend can handle about -.5 camber before you start munching bearing seals.
Old Oct 16, 2013 | 11:47 AM
  #131
Jenson's Avatar
Wow...thats it? I have a buddy who regularly does it to mustang 8.8's, so we were going to sort of rig up his jig for the 10 bolt. Im pretty sure he said he was adding 1.5* though, and a touch of toe in.
Sporty, you definitely need to lower that 4X4!!!
Next week, I'm finishing up the custom ebrake setup, and hopefully the mold for the carbon dash. This week is replacing the engine in a 2500HD, but I get to keep the LQ4...for what reason idk.
Old Oct 16, 2013 | 11:16 PM
  #132
Sporty-X's Avatar
http://www.youtube.com/watch?v=XyqGE...ature=youtu.be
Old Oct 17, 2013 | 04:55 AM
  #133
Sporty-X's Avatar
Any help in choosing springs rate for front and rear and let me know how much to lower the car ?
Also are the BMR adjustable arms better than the UMI ?
Another question : which types are you using?
Old Oct 17, 2013 | 07:24 AM
  #134
Jenson's Avatar
Cant go wrong with the Strano's
http://www.stranoparts.com/partdetai...=115&ModelID=8
IIRC the pro kit is also 550 front but 175 rear.
You want a full length TA, either of those is fine.
I went with the Global West trac link since it tucks up more and sort of de-couples. Well, I will this season at least, only thing I havent purchased yet.
Old Oct 17, 2013 | 02:07 PM
  #135
Lemme know how your rear end goes. Could you document it since not many people do this or have even heard of it. lol I would kill for -1 camber and some toe in from my rearend!
Old Oct 17, 2013 | 05:39 PM
  #136
RogueFab's Avatar
Nice build. Need more sideways pics
Interesting take on the steering setup. I usually see cut up knuckles, never a bolt on affair. Cool.
Old Oct 18, 2013 | 01:28 AM
  #137
Sporty-X's Avatar
IIRC the pro kit is also 550 front but 175 rear. .
you suggest these springs so ? ok asking Strano for a quote
You want a full length TA, either of those is fine..I went with the Global West trac link since it tucks up more and sort of de-couples. Well, I will this season at least, only thing I havent purchased yet
I was talking about the A-Arms. i beleive i will chose the UMI adjustable ones
Also : what wheels and tyres are you using ?
Old Oct 18, 2013 | 09:15 AM
  #138
Jenson's Avatar
Definitely. Yea -1 is all I want realistically.
Yea those are good springs. Search around and you'll see tons of people running them with good results. You should be able to order them from that page. The cool thing on the strano's is they're lighter than the eibach's.
Oh A arms, Spohn all the way. Best design, cheapest, and the most clearance.
On the welded 45* setup I was running some xxr's that were 17X9 +20mm offset with a 5/16" spacer. With a 255/45 clearance at full lock was 1" to the stock lower A arm. Then tons of 17X9.5's out back for 275-295's
These are my new front wheels for the 66* setup. Cheap wheels are good cuz your going to ruin them anyway and you'll never really go much faster than 80-90mph, if that.
http://www.ebay.com/itm/JD-Wheels-17x8-BOSS-338-Black-5x4-75-2-4-517-bs-3382-8834-GM-Chevy-Rims-PAIR-/230817831572?pt=Motors_Car_Truck_Wheels&hash=item35bdd09a94&vxp=mtr
Old Oct 23, 2013 | 02:44 PM
  #139
Sporty-X's Avatar
Strano isn't answering my emails ... Still waiting
Old Oct 23, 2013 | 04:00 PM
  #140
Jenson's Avatar
Did you email him just to see if he would ship there? We may have to do a separate shipment for the springs if he doesnt answer you. Maybe try WS6 store and the pro kit or bmr springs.
