4th Gen drift build
I just bought one of those chinese cut50 plasma cutter's, so hopefully progress can resume on my car soon. Probably after I install the lift though. There's never enough time in a day and this dark at 5pm stuff makes 7pm feel like 11.
Zex, you are correct on the way they bolt up, thats just my test fixture. I use the two holes to machine the second side. Then drill them out and C'bore one for a little clearance. The 45's will work with GTO wheels and a spacer. Spacer thickness will depend on tires and lower control arms. I'm running 17X9 +20mm wheels and they clear with 5/16" spacer on stock A arms with a 255/40. You can also keep your sway bar with the 45*. Bracket is made from 7075 billet, NAS bolts, QA1 rod ends, K nuts, and high misalignment spacers all included. The whole kit will just bolt on using your two factory bolts and two supplied bolts. There is also a cone bushing that goes in the upright where the stock tie rod goes. The rod ends are LH thread so toe is adjustable on car and all you have to do is back off the jam nut. Detailed pics and instructions are included. Cost is set at $475 as I use high grade stuff. Hopefully more pics tonight or tmrw...C'mon Mr UPS man!!
If I end up keeping my T/A I'll be in for a set, I've been practicing drifting more for the last 2 months and love it- minus the horrible stock radius/ angle.
So last night my best friend murphy came by and borrowed my gorilla lug nut key...I turned the shop and house upside down trying to find it.
thx
