OEwheel options for RR, what do you think?
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
So I'm currently running a set of 4 chrome zr1 9.5" wheels on 275/35/17 NT05 rubbers and was wanting to upgrade to a 315 wide tire on all 4 corners. At first I started looking for some used CCW classics but started pricing out OEwheels that would be less than half the cost new.
So my first instinct was to go with a silver zr1 wheel 17x11,bs=8",os=50mm, which I've heard won't give any problems. Now I'm looking at these http://www.oewheelsllc.com/Wheels_3/...Wheel-gunmetal. An 18" wheel will let me run a big brake kit in the future which sounds nice. Specs are 18 x 10.5 bs=8", os=56mm. I'm novice at wheel specs so I don't know if I'll run into problems mounting these wheels. I read in another post that a 1/4" wheel spacer on the fronts will be needed to clear the caliper. Will I be able to mount a 315 tire to a 10.5" wheel? Do you for see a problem with this wheel if/when I do upgrade to a big brake kit? Thanks for your input guys, just want to cross my t's before I pull the trigger.
Which brake kit do you plan on?
17's will clear a c5 or 13" rotor combination...probably will still need the spacer. I needed one.
18's will let you go up to 14" or newer GM rotor combination (c6, cts-v, etc.). Probably will still need the spacer to clear most large calipers in this category.
Thanks for the replys. Planning on upgrading to a 14" BBK or do the C6/Z06 upgrade.
Jeff, that's exactly what I plan on doing. Thanks for the pics, I figured someone here had to have used those wheels. For the price you cant beat it. I'll be in it wheels and tires for the same price some used forgelines/CCW's would cost.
What size spacers are you using? What's your clearance look like with the LS1 spindles and C5/C6 calipers.
Brake Caliper Clearance
would love to see some pics of your Trans Jeff94TA. You have pretty much exactly what Im looking to starting to build right now.
I worried, about brakes at the moment. You have C6 fronts? Are they the base front or the Z06's? I have 17"x8.5 fronts, and worry that I wont be able to clear the calipers on a larger than stock rotor.
What has more braking power, 4 piston calipers with a smaller rotor, or 2 piston calipers with a larger rotor??
OP: the wheels pictured look sick, OE makes good stuff. Youll be happy you went with them.
I think you should clarify your question about brakes. Are you looking for stopping distance for daily use or brake consistency for racing use?
In theory, a larger surface area (larger pad and rotor combo) will stop shorter than stock. But this can be misleading depending on your application.
More pistons will give you more consistancy...usually want road racers want. I have 6 pistons up front and they are way more consistant than my oem. But that also has to do with pads, rotor design, and size.
The tires you have pictured above, are they on a 8.5" rim?? Im trying to figure what is the widest I can go on these wheels without issue.
Also, a 315 on the front with a 5/8" spacer is going to put a lot of stress on the front wheel bearings. I hope you plan to replace these often considering the weight of the wheel, the width, how far out the weight is, and the abuse it will be seeing.
My suggestion - a brake duct kit directed into the center of the rotor should help keep the bearings cooler - not to mention - the brakes themselves. These cars are heavy, and it doesn't take much to spread the calipers. I've lived it and Learned it.
picture above is on stock 17x9...or 17x9.5...I can't remember what OEM size was for 1997 SS.
For now I only auto-x. I need to vac the brake lines and upgrade the brake fluid. Plus, i'd like to run a set of ducts as '01 ss vert' mentions. I'm trying to decide what path to take.
315's are a lot of stress...I agree. I'm curious as to how much damage I will rack up with 295's in front.
