Road Racing Road Course | Autocross
2002 ws6 m6 build options
Old Dec 17, 2015 | 12:38 AM
NitroFumesAteMyBrain's Avatar
Default 2002 ws6 m6 build options
I recently acquired a basically bone stock 2002 ws6. I live roughly an hr from high plains raceway just east of Denver and have a lot of interest in making multiple open lap days. There is also a local 2 day cannonball run through the mountains that I would like to participate in as well.
This car will also be a nice weather/weekend driver, not a daily. It will see some canyon driving on the weekends. If you had a clean slate like I do with this car where would u start? I'm a drag racing convert, worked in professional drag racing for almost a decade, but turning while going fast is new to me and I bought this fbody intentionally for this purpose.
I know I know, why not start with a c5? Because I have a wife and kid and they like to cruise too, lol.
So where do I start on a basic track day car that's gonna see drive miles as well? Springs/shocks/sway bars? I'd also like to make a cam and full exhaust swap. Any thoughts on cams? I was looking at the Texas speed 228r and the vengeance vrx4. Both are below .600" one is on 112 one on 114. Is this too much cam for a road car?
Old Dec 17, 2015 | 07:58 AM
SAPPER's Avatar
Just like any type of racing, suspension is key. My son started with a bone stock 02 Z28 that he picked up for $2k in very good condition. So far he has only less than $5k in the suspension and that's everything under the sun except a Watts linkage, which he doesn't really need. It's all UMI. He invested in the Road race stuff too. The stronger K-member and the boxed front LCAs with Rotojoints throughout and Viking dual adjustable coilovers. That's overkill for most and about a grand more than needed to be spent.
But a good start is tubular k-member and upper and lower control arms to lighten and strengthen the front end, then of course replacing all that stamped steel garbage in the rear.
Then of course tires.
Depending on how serious you want to get is what will decipher how intense the parts are. But UMI, BMR and Founders all make good stuff. At a minimum, you're look at 3 point SFC, LCAs, Tq arm & PHR. That will get you handling pretty damn good with good tires.
Also, be aware the if you choose a relocated torque arm, you won't be able to lower the car much. I adjusted my sons coilovers to have a good stance and the tq arm crossmember was about 2" off the ground. He hit everything.
Cams. look into Brian Tooley racing. Headers, look into Speed Engineerings 1-7/8 kit. Awesome price and fits like a glove.
Old Dec 17, 2015 | 10:01 AM
Midnight02's Avatar
I would start with the basics: shocks/springs/sway bars and brake pads. There are a bunch of great options out there, however I went with Bilstein shocks, Strano springs and Strano's sway bars. Makes for a tight little setup on track.
If you're inclined to spend up now in favor of "doing it right the first time", go with Koni Sports for the shocks. I've been pleased with the Bilsteins as a budget option, however the Konis are simply better.
If you're new to road course track days, there's a nice benefit to starting out on street tires -- most give audible feedback when you're close to the edge and they are enough of a limiting factor that it helps you focus on improving other aspects of your driving. As you develop, going with a set of dedicated track wheels and R-compounds will do a LOT to improve the way the car handles on track.
As for brakes, you can easily get by with throwing a set of aggressive track pads on the front and something very mild on the rear. I run Hawks pads primarily because I swap back and forth for street/track. On track I run either the DTC-60 or DTC-70 on the front and the HP+ on the rear. I wouldn't even consider anything stronger than the HP+ on the rear as that would lead to excessive rear wheel hop under heavy braking. Another direction would be to consider the Wilwood package Strano is offering -- this would be a big improvement over the stock setup at an appealing price point.
There are plenty of other items you can work on down the road, however it's worthwhile to get some seat time in the car first. Having a good baseline for how the car handles in stock (or close to stock) form will help you with future adjustments on other mods.
Old Dec 17, 2015 | 10:09 AM
beach cruiser's Avatar
I ran my WS6 on track for a while until my track only car was finished. I had an ESP legal setup on my car and it was quite the track performer. Strano Springs, Koni yellow shocks, upgraded bushing to prothyane, and beefed up adjustable rear suspension links. Also have an adjustable panhard rod. You may also find you will want to change out the diff, I have an auburn road race spec diff in my car. Leave the motor stock for a while so you can work on the connection between the seat and the steering wheel. Good tires should also be on your list.
Old Dec 17, 2015 | 10:36 AM
SAPPER's Avatar
Good advice. Especially in the bold
Old Dec 18, 2015 | 06:48 PM
JD_AMG's Avatar
With all due respect I couldn't disagree more.
Most the parts you named do little to nothing for handling, I have all of the above minus the K-member and front control arms.
With suspension you want to start with good shocks first, they will make the biggest difference out of any suspension piece you can buy.
Something like Koni SAs, Penski, KW, race bilsten, or UMI's new special valved coilovers.
Shocks like QA1, Viking, Afco, and strange are NOT handling shocks, they are drag shocks with marketing toward "protouring", but are really just drag shocks.
Next would be springs, and or swaybars (strano for both ideally)
Then a panhard bar to recenter the rear end unless you have the cash for a watts link.
THEN if you want a little more out of the car you can consider rear LCAs(not poly), a full length adjustable torque arm, road race K-member (only from UMI) and front control arms. Lastly you can consider SFC's but be warned they add weight and don't make you any faster, the added rigidity is unnoticeable, if its there at all (I have 3pt that are welded in, did nothing. However I fixed the real issue first: the shitty stock shocks).
Are you talking about the short torque arm? If so thats a drag piece, for handling you want a full length torque arm, and relocating it off the transmission shouldn't change the height at all.
As for a cam, for now forget about it, you are still in a drag race mind set. Keep it bolt ons for now until you finish your suspension and brakes, those are what will get you around a track/through the canyon runs fast, not a cam.
Old Dec 19, 2015 | 08:01 AM
I agree with JD AMG above, but he left out tires. Good tires are essential. I would say spend money on tires and shocks, then HPDE/seat time. After you learn how to not get passed by Miatas then start working on the List above. Stock shocks, and hard tires will put you in the wall, and make you go back to drag racing.
Old Dec 19, 2015 | 01:05 PM
On the Strani site which shock and spring set? I assume the strano sp141 springs, and either the koni sport or bilstein hd shocks? 35/22 sway bars?
Old Dec 19, 2015 | 01:06 PM
I see a few wanting to increase spring pressures a touch on the strano springs. What about knocking 1/3 of a coil off the stranos?
Old Dec 19, 2015 | 08:47 PM
FIVEPOINT7's Avatar
The SLPs will be better than stock, but ideally go for Koni 4/3 or 4/4s. The car I race just got vikings put on it, which I'm skeptical of, but it's not my car, so hey, I'll drive what I'm given.
Old Dec 19, 2015 | 11:56 PM
JD_AMG's Avatar
The Koni SA's, 4/3 or 4/4, your choice.
Strano springs
Strano swaybars (35mm/22mm)
Where did you read this?
His springs are designed specifically for f-stock auto-x, and used to win multiple national championships with, they work.
If you want to increase spring rate then buy springs with custom rates (he sells other springs as well you can talk to him about), you do NOT want to cut lowering springs, and for ideal handling you do not want to go lower than ~1.25" that the strano springs already drop (you NEED suspension travel for the suspension to actually work).
Old Dec 20, 2015 | 12:42 AM
I could have swore the stranos were only a 3/4" drop. If they're more like 1.25" there's no wiggle room.
I read a few times digging through threads on here and various sites about drivers looking for a bit more spring, not a lot, just a touch more. If the stranos only dropped 3/4" and needed a touch more rate, a 1/3 of a coil would drop everything slightly and add 30# or so to the rate. But like I say, if they knock 1.25" there's no room for "adjustment"
Old Dec 20, 2015 | 02:02 PM
79_T/A's Avatar
You can't cut coils and know ahead of time exactly what the rate is going to be. If you need more spring rate, buy stiffer springs instead of ruining a perfectly good set of springs. That way you know exactly what you are getting. Can't tune a chassis around an unknown spring.
Old Dec 20, 2015 | 02:05 PM
79_T/A's Avatar
Sorry but this is not good advice. K member and lower control arms should be the last thing touched. Also, Viking shocks are far from ideal from a handling perspective. One last point, a properly designed torque arm will never drag the ground. I'm assuming this is a short torque arm, which has no place on a car set up to handle.
Old Dec 20, 2015 | 04:56 PM
Those running bilsteins, are you on the slp or hd shock?
Old Dec 20, 2015 | 05:04 PM
Pretty sure I'm going with the strano susp. Package with the sp141 springs, bilstein shocks, and the 35/22 hollow bars....seems like a good way to spend a thousand dollars.
Car already has lower control arms and tubular trans tunnel brace, so a torque arm and panhard rod will come after the above pieces along with some updated brake pads and rotors. After that we will go see how she does. I'd almost like to take it as it sits for a half day session just to see the difference....maybe.
This seems like the correct progression parts wise correct?
Old Dec 20, 2015 | 05:30 PM
JD_AMG's Avatar
Get the koni sport single adjustables, shocks will make the most difference so it would be better to spend more now on them and skip something else until you can afford it later.
The bilstiens are not bad by any means but do not compare to the konis, especially if you are tracking the car.
What bushings are in those control arms?
Old Dec 20, 2015 | 06:30 PM
Chris Paveglio's Avatar
I also agree with JD-AMG and others. Get the KONI shocks right away. They do make the biggest and best difference first.
Also, do not buy a new K member, ever. It's a complete waste of money. The stock unit is more than adequate and aftermarket units are more fragile and don't save a lot of weight. I'm sure there are threads about it here.
Also maybe check in to the FRRAX forum for advice from dedicated road race and autocross guys.
Old Dec 20, 2015 | 08:44 PM
ya, the more i price things out the more sense it makes to run the koni shocks from the get go. sourcing the konis, springs,bars,torque arm, and panhard im around 2k, not too bad when half of that is shocks.
ill have to check the bushings in the arms....are the poly bushings not what you want?
Old Dec 20, 2015 | 09:09 PM
frrax site not accepting new members?
