Road Racing Road Course | Autocross
Anyone using a Wavetrac?
Old Aug 27, 2018 | 07:58 AM
ND2RACE's Avatar
Default Anyone using a Wavetrac?
So forgive my hodgepodge of performance parts, my 2002 Camaro was a 10 second auto car, and has been modified into a T56 “fun” car. It has a Moser 9” with 4:10s and a wavetrac, Strano springs, sway bars, Koni yellows, and I’m using stock 18x9.5 Vette wheels with 275 RE-71Rs on them. So a lot of the drag race stuff is gone, but that’s why the 9”. So I took it autocrossing for the first time over the weekend. It did surprisingly well, especially compared to my C5.
What I’m a little concerned with is how applying power out of a turn it would only spin the inside tire. I expected it to break loose. I doubt there is anything wrong, it still spins both tires in a straight line. Just not how I expected it to act, even made the car more forgiving. I’m just wondering if anyone else has had experiences like this?
Old Aug 27, 2018 | 08:53 AM
cam's Avatar
cam
I ran a T2R for years and never lit up an inside tire, but never really stepped it out sideways either. Definitely a noticeable improvement in road course driving experience for me. I loved that carrier, it was the best and my favorite to date but alas, I blew it to bits from a dig
Old Aug 27, 2018 | 01:24 PM
Jeff94TA's Avatar
What fluid are you running in it? Torque biasing differentials don't like additives of friction modifiers because they function on friction. I'm not familiar with Wavetrac's but I've always run Redline 75w90ns in my Torsen T2R and had great success.
Old Aug 27, 2018 | 02:27 PM
Chrisingermany's Avatar
I've been running mine since May of this year. First time really getting on it was at LSfest West (just finished the break in miles and fluid change the night before). The thing is a beast for sure. I really forget that it's back there and seeing the title of your post mad me think to myself of how well it has performed without me even noticing it. Never noticed the inside tire or anything but smooth transitions. My car is mainly auto-x, and was just at a road race event on Friday and it performed flawlessly. Using the Lucas oil with it.
Old Aug 27, 2018 | 02:42 PM
cam's Avatar
cam
Ohhhh sweet an S-Trac!!!
Old Aug 27, 2018 | 08:09 PM
Floorman279's Avatar
yea was goona say, chris thats the s trac.....the wavetrac is the moser equivalent......i have read so many "questionable" things about the moser stuff on this forum, but not once have i read anything bad about strange.......
Old Aug 27, 2018 | 08:10 PM
chris, pretty ballsy of you to run the aluminum center section on a street car
Old Aug 27, 2018 | 09:12 PM
ND2RACE's Avatar
I’m using the Motul fluid that Moser sells for it without any additives.
Old Aug 28, 2018 | 01:54 PM
Yeah, sorry fellas. It is totally a S-Trac. I was going to run a wavetrack and the guys at MWC told me the S-Trac will work just as good and they have had very few complaints about them. Complete brain fart responding to this thread. But S-Track should be on your scope as well if looking at the wavetrack.
It's the thru-bolt aluminum one so should be just fine from what I was told.
Old Aug 28, 2018 | 02:11 PM
Now that I think about it a bit, the HD Pro aluminum case is another reason I went S-Track. The wavetrack will not fit in the aluminum case.
Old Aug 28, 2018 | 05:06 PM
ND2RACE's Avatar
My Wavetrac is in a Moser aluminum case. Maybe not whatever Strange HD Pro case is, but it fits in Moser’s through bolt aluminum. Idk?
Old Aug 28, 2018 | 06:40 PM
i thought MWC didn't recommend aluminum for street use.......dont quote me on that, i believe i asked them and that was kevin's response......not certain tho
Old Aug 28, 2018 | 07:59 PM
Toes's Avatar
I have 5 years on my aluminum center section. Street an drag use. No problems no leaks. Also with a S trac, had 4.30 an swapped to a 3.90.
Old Aug 28, 2018 | 08:54 PM
his response then may just have been "you dont need it"
Old Aug 28, 2018 | 09:02 PM
cam's Avatar
cam
Aluminum case is totally fine for the street. Used in OEM all the time. Sierra front diff for instance, transfer case, transmission anyone? You get the picture.
Speaking of the S-Trac I havent been on top of things as much as I used to so does anyone know of ANY S-Trac failures? I do know there were some Wave-Trac failures because initially those carriers came with a lifetime warranty and that policy soon changed. Thats not to say Im suggesting the WavTrac is in any way bad it is not at all it is pretty dang awesome but our kind tend to break all things sooner or later.
Old Aug 28, 2018 | 09:21 PM
not enough people spring the extra money for the s trac to answer that question....at least on ls1tech
Old Aug 29, 2018 | 08:44 AM
cam's Avatar
cam
Ha yes indeed how things have changed around here in that regard. LS1tech was once among the most spendy membership of any engine performance site and now the kings of the JY dogs. The irony is the JY dogs are going WAY faster than almost all the big dollar og members ever did. Interesting times
Old Aug 29, 2018 | 09:52 AM
Probably a Strange only kind of thing. I remember something saying that you would have to take out material to make it fit and that it would make the area weak or something to that effect.
Old Aug 29, 2018 | 07:18 PM
i try to go used when i can
Old Aug 29, 2018 | 07:23 PM
The wavetrac may not carry the warranty anymroe but the STrac is still standing tall
