Racing Oil?
It runs strong but has a ton of blowby, which is common, and if run it hard will push oil dipstick out.
My question is can I use a thicker oil to help reduce blowby? Like 15w50? or similar
I currently run Driven DT40 5w40 oil.
Driven DT40 5W-40 is a good oil for your application and use. I don't think there's much you could do on the oil end to help with this. A lesser, more volatile oil would make the situation with the catch cans worse regardless of the viscosity. Driven DT40 5W-40 is less volatile than Mobil 1 15W-50, for example.
