Will wrong valves seals do this?
Old May 6, 2008 | 07:08 PM
Stangkilr's Avatar
Default Will wrong valves seals do this?
Im just curious. Looking for input here.
Two sides look different?
Old May 6, 2008 | 07:17 PM
Bill Bowling's Avatar
I do not think valve seals would do that. Did it break when driving or when you were taking it apart?
Do you have stock heads? Were they ported?
Bill
Old May 6, 2008 | 07:20 PM
Stangkilr's Avatar
It is bad news. Do you have stock heads?
Bill
Broke when driving, they have around 400 miles on them. They are cnc ported LS6 heads. I was told this happend because I used a factory valve seal.
Old May 6, 2008 | 07:32 PM
TLewis4095's Avatar
Would be impossible for seals to do that....looks like the geometry was wrong....spring bind possibly...but no way valve seals! Looks like the port work may have weakend the area that broke.
Old May 6, 2008 | 07:33 PM
Tally TransAm's Avatar
theres no way a valve seal will cause that
although im very curious as to what did
SIC LSX's Avatar
Valve seal have nothing to do with that! It's all on the heads being ported to much and loosing the strength its ALU you can only go so far! I have seen people use stock valve seals with Patriot and prc dual valve springs and that didnt happen! I was going to get PRC heads but ill just save up more for some Trickflows
Old May 6, 2008 | 07:56 PM
Stangkilr's Avatar
What you guys are saying is what 3 people told me after I got off the phone with the sponsor. Im a service advisor, and first thing I did was ask the heavy line guy and he laughed.
Old May 6, 2008 | 08:00 PM
djsanchez2's Avatar
Yup the fellas are right. It was either the porting that caused the structure to fail or an issue in combination with that, springs, pushrod length, etc.
What moron told you that?! He needs to be slapped. No possible, incorrect sized valve stem seals will just make the engine smoke. Lol. I gotta show my dad this one.
Old May 6, 2008 | 08:01 PM
Stangkilr's Avatar
They said that their dual spring kit comes with special valve seals/seats. In this case the heads already came with these seals on them new from the shop. I just figured they were good to go.
Old May 6, 2008 | 08:07 PM
Stangkilr's Avatar
Here is what I dont get, look at the picture of the two heads together. If these are cnc ported shouldnt they look the same?
Old May 6, 2008 | 08:46 PM
Stangkilr's Avatar
you should not have to pay anything to get them replaced no mater what!!!
At this point I dont think I should have to pay $800 like they want. I can understand if I did forget to install something but these were already on the heads from TSP. I ran stock valve seals on my last set and had almost 9k miles on them with this MS4 in the car. I ordered a new set of valve springs today to throw on a stock set of heads just to get my car going again.
Old May 6, 2008 | 08:55 PM
Gunnar@Patriot's Avatar
On the dual spring, you do not need to run the stock seals. If you decide to go with another set of heads, let us know. We can make you an excellent deal on a set of ported 243's or 5.3 heads.
Old May 6, 2008 | 09:31 PM
Stangkilr's Avatar
So I should not run the stock valve seals? I have never had one issue in doing this. It is okay to run with the factory seals though right?
Old May 6, 2008 | 09:41 PM
mvvette97's Avatar
I can tell you this, when i bought my Patriot golds springs they came with new valve seals, they are the same seal as the factory seals. The seals didn't break the heads anyway. I will bet anything that they were ported too thin in the intake runners. Put dual springs on with a head that is ported too thin and it's gunna break.
Old May 6, 2008 | 09:42 PM
Stangkilr's Avatar
Originally Posted by AutomagicLS1
Arent you now another of about 5,000 people that TSP's **** has done this to people. How in the **** could TSP say it's the wrong valve seals when its the same thing that has happend to 5,000 other peoples heads and now you. Thats pretty hilarious if you ask me. TSP needs to backup their product for you like they have done to tons of other people with the same problem
I have no idea, all I know is I have these new heads that are worth what the recycling place will offer. They were nice on the phone, I was too but after talking to people and thinking more and more about it I just dont see eye to eye. For one thing they have a history of this happening from reading around. Two you can clearly see the difference in the porting of the two heads. Three I dont see what the valve seals have to do with the heads coming apart when I ran the same setup on my stock PORTED heads.
Old May 6, 2008 | 10:17 PM
5.3LJimmy's Avatar
It could be caused by the wrong seals if the retainer was hitting the seal and causing it to bind. Or if the inner spring was stuck on the seal and causing coil bind due to the larger diameter of the stock seal. It looks like there is a fair amount of material left in the port roof. Some of the older heads I saw pictures of were half that thick where they broke off. I'm not saying it can't be a head problem, just trying to give you a few things to check to help eliminate some possibilities. I would also like to know if the heads are milled, what length pushrods, what head gaskets you're using, and if you have flycut the pistons. And I would like to see a side by side comparison pic of the heads so I can see what you mean by the port differences. They should definitely look identical.
Old May 6, 2008 | 10:20 PM
Area47's Avatar
id really like to know, how in the hell a valve seal has anything to do with a head destroying itself.
oh, thats right.
NOTHING!!!!
i can see putting in valve seals when you have an issue with oil consumption. not when you are spinning the motor an asshair past the factory rpm limit.
::shrugs::
id say more, but knowing my luck id get banned from here too
Old May 6, 2008 | 10:23 PM
Stangkilr's Avatar
Wow, I hate hearing this stuff. I have had nothing but good things to say about TSP. I can count almost 4k in reciepts I have with them. I think I have installed 20k worth of TSP parts on other peoples over the last two years. The only one who had any problems with them was my friend Tim, his heads were messed up. When he needed his car done I put my own TSP heads on his car because he could not wait on tsp to send him the replacements. I dont drive my car everyday and already had it apart so I told Tim id take his heads once they come in since they were the same thing. The heads I got are the ones im having problems with. Texas-speed would not cover them 100% since im not the original buyer. I dont see why it makes any difference because if they look in their history they will see I bought a set of LS6 heads anyways which ended up on his car. I was just helping a friend out by getting his car on the road faster.
Old May 6, 2008 | 10:27 PM
Stangkilr's Avatar
Look at the picture where it shows both installed on the car. Check out the difference in the corners. They were not milled, just ported LS6 castings using stock valves, 7.4 pushrods, factory mls gaskets. Also they are factory LS6 seals.
Old May 6, 2008 | 10:46 PM
5.3LJimmy's Avatar
IT is possible for the stock diameter valve seals to snag the inner spring. A friend of mine installed dual springs with the stock seals and all but one inner spring broke. That's why the dual spring kits come with the smaller diameter viton seals.
