Looking to trade my Build Fbody for a C5 or ls2 C6
Looking to trade for a C5 maybe c6.
Always wanted a C5, and I'm almost done with my other FBodys build. Would like to trade for a clean c5 or ls2 c6. Wheels Stay with me. I can Have the Car on C6z Wheels with new tires for you. or you can put your Vettes wheels on it.
1993 Camaro z28
108,000 miles on the Body
3" Cowell hood
ShortBlock:
GM l99/ls3 Block
Motor was assembled by:
Scroggins Machine Shop in Houston
Balanced and Blueprinted
4" Callie's Compstar Crank
6.125 Manley H-Beam Rods
Wiseco 4.070 bore Pistons
Upgraded Pins
Upgraded GFX Rings
ARP Main Studs
ARP 2000 Rod Bolts
King Bearings
Rings are gapped for a 300 shot
Compression of the motor is 12.2-1
Top End of the Motor:
799/243 Heads
Milled .020
Ported/Polished by Daniels Speed and Perf
ARP Head Studs
Ls3 Head Gaskets
Ported Fast 92 Intake Manifold
Nic Williams 92 TB
LS7 100 MM Mass air Sensor
Custom 4" CAI
New LS7 Lifters
New GM Lifter Trays
Hardened 7.400 Pushrods
.660 lift Dual Springs
GM Rockers with Comp Trunion Upgrade
Custom Grind Comp Nitrous Cam - Have Specs for people interested
Exhaust:
17/8 Stainless Steel headers- Speed Eng
Custom 3.5" Stainless y-pipe
Custom 3" stainless Exhaust over the axle
Magnaflow Muffler
Dumped under the car
Exhaust done by Best Automotive
Kingwood, Texas
Transmission:
Built T56
Carbon Fiber Synchros
Bronze Shift Forks
Billet Gears
Clutch:
Textralia ExoSkell
Triple Disc Clutch
Textralia Spec'd Slave Cylinder
Fuel System:
Custom RaceTronix
340 Pump
-8 fuel line
-6 return line
RaceTronix Regulator
Fuel Filter
Billet black Fuel Rails
42lb Ford green top Injectors
Rearend:
2002 SS 10 Bolt
3.73 Gears
Welded axle tubes
Braces front and back
Stud and Girdle kit
Brand New Seals and Bearings
1 Piece Aluminum Drive Shaft
Suspension:
Short Arm Torque Arm
Drive shaft Safety loop
1.5" lowering springs
Lower Control arms
Pan Hard Bar
Solid Spohn Motor Mounts
Interior:
2002 Trans Am Leather Seats
Perfect dash
Perfect interior
Radio:
Sony head unit
10" Sub
500 watt Amp
Misc:
Glow Shift Wideband
Hidden Nitrous Bracket in Spare tire
Tuned By:
Alex Peitz
Peitz Performance Tuning
1993 Camaro z28
3" Cowell hood
ShortBlock:
GM l99/ls3 Block
Upgraded Pins
Upgraded GFX Rings
ARP Main Studs
ARP 2000 Rod Bolts
King Bearings
799/243 Heads
Milled .020
ARP Head Studs
Ls3 Head Gaskets
Nic Williams 92 TB
Custom 4" CAI
New LS7 Lifters
New GM Lifter Trays
Exhaust:
Magnaflow Muffler
Kingwood, Texas
Transmission:
Built T56
Bronze Shift Forks
Billet Gears
Clutch:
Textralia ExoSkell
Triple Disc Clutch
Fuel System:
Custom RaceTronix
340 Pump
-8 fuel line
-6 return line
Fuel Filter
Rearend:
2002 SS 10 Bolt
3.73 Gears
Welded axle tubes
Stud and Girdle kit
Suspension:
Lower Control arms
Pan Hard Bar
Interior:
Perfect dash
Perfect interior
Radio:
Sony head unit
10" Sub
500 watt Amp
Misc:
Glow Shift Wideband
Tuned By:
Alex Peitz
