Rectangular to Cathedral adapter?
Old 01-18-2016, 11:31 PM
  #81
LilJayV10's Avatar
Originally Posted by Third-Gen
math.....lower pulley diameter:upper diameter. we can watch slip in the ECU with a PD blower. A lot harder to do with a centri. You could use a dual channel optical sensor but I havent had time to build one yet.
Yeah it is. We have talked about an optical sensor or something similar but that's as far as it's gone.
Old 01-18-2016, 11:46 PM
  #82
Third-Gen's Avatar
i could build one from an Arduino with outputs on a small LCD but my plate has been pretty full filling orders for parts. Definitely on my to do list.
Old 01-21-2016, 08:53 PM
  #83
omc8's Avatar
Bobfig, the machine time is like 27 minutes on the big machine, problem is that it's been down for a month, and I'm running on my backup machine, which is a precision one, aka slow as crap. Once the big machine is up again I will have shelved stock, but right now they are made to order as I need them.
As far as an ls3 intake on ls1 heads, it won't work. The flow direction will abruptly change TWICE before it goes into the heads. The blower works because the air enters the head vertically, instead of perpendicular to the intake port surface as with a standard manifold. The air would make a Z path, not a straight one. Get an LS2 manifold and be a lot happier.
The air flow path making a Z , is it the floor impractical that you are referring to ? I could see once it drops off the LS3 flange , it would have to climb back up the ramp of the floor.
Old 02-22-2016, 02:45 AM
  #84
Third-Gen's Avatar
I've actually gone over this before. There was another thread on here that had a drawing that the admins deleted. The entry angle of the lsa blower is vertical, so if you used an ls3 manifold, it would essentially hit the wall of the adapter, be directed downward, then hit the floor of the port in the head, and have to change directions again to flow towards the valve.
Old 02-22-2016, 07:29 PM
  #85
omc8's Avatar
Thank you for the reply back, sorry to make you cover the same ground twice. I would like to have seen that drawing , don't understand why it would have been deleted even if there was a another sponsor on here selling this adaptor plate .I still don't know what wall your refering to by hit the wall.. I would describe it like a waterfall , then climbing up a hill to to the bowl.
Old 02-22-2016, 07:35 PM
  #86
Third-Gen's Avatar
This is an insanely innacurate. picture, I can't find the other one. The angles in real life are a lot more drastic.
Old 03-11-2016, 01:01 AM
  #87
Third-Gen's Avatar
Customer sent me a pic of how the Ebay spacers fit. Realllll nice. NOT. Mine are on the left, ebay on the right. What JUNK!
Old 03-14-2016, 09:34 AM
  #88
ryeguy2006a's Avatar
Oh...yeah that is pretty bad. Any updates on those dyno charts?
Old 03-14-2016, 11:17 AM
  #89
Third-Gen's Avatar
I'm trying to upload a few pics but I'll have to do it from my pc. 5.3 made 550ish. 500 ft lbs from 3000rpm and up.
And another user on here is also on performance trucks and he posted some vids. Here's the link.
http://www.performancetrucks.net/forums/forced-induction-159/lsa-blower-2000-silverado-can-i-use-lsa-map-sensor-540880/
Old 03-15-2016, 09:18 AM
  #90
DETROIT_AREA_00_SS's Avatar
I'm assuming these would work on a junkyard 5.3 mated to a kenne bell ?
Old 03-15-2016, 06:58 PM
  #91
Third-Gen's Avatar
these will work to convert any blower from square port to fit on cathedral heads. doesnt work well if you are trying to use a stock manifold though.
Old 05-20-2016, 12:05 AM
  #92
bmf5150's Avatar
You have a website???
Old 06-18-2016, 12:39 PM
  #93
bigdaddy350's Avatar
Ictbillet.com sells some.
Old 06-18-2016, 06:37 PM
  #94
Third-Gen's Avatar
Olson kustom works. Okw-inc.com
Old 06-18-2016, 06:38 PM
  #95
Third-Gen's Avatar
Ya they copied my design just like lsx precision. Mine are still cheaper and fit better.
Old 06-18-2016, 07:24 PM
  #96
ramairetransam's Avatar
These are cool , a nice option to have out there. Nice work
Old 08-17-2016, 02:42 AM
  #97
Third-Gen's Avatar
Lots of LS Cathedral installs going on lately. Most of them used our in house parts or a combo of OEM and ours.
Old 02-16-2017, 12:43 PM
  #98
Ozz1967's Avatar
you just gave me hope to have this possibly fit under my third gen hood. Does it's sit any higher than it would if using normal LS3 style heads?
Old 04-08-2017, 08:36 PM
  #99
Third-Gen's Avatar
the blower with lid is about the same height as a truck intake. so i doubt itll fit under a stock 3rd gen hood even with ls3 heads, but the spacers add 1/2" overall if you have to use them
Quick Reply: Rectangular to Cathedral adapter?
