1970 caddy sedan deville(sinister) lq4 s475 turbo cam=)
Old 10-28-2016, 06:41 AM
  #221
Schnitz's Avatar
Congrats! I've been following since day 1. Your build gives me hope. Cheers!!
Old 10-28-2016, 12:03 PM
  #222
slocaddy's Avatar
Thanks, good to hear, do you have build thread on your car?
Old 10-28-2016, 12:28 PM
  #223
slocaddy's Avatar
Old 10-28-2016, 06:32 PM
  #224
slocaddy's Avatar
thinking this would be a nice home for meth nozzles, if a third ever becomes wanted/needed I'll give the same spacing, just closer to the blowoff
Old 10-28-2016, 06:47 PM
  #225
slocaddy's Avatar
I like this better astheticly, also can put second solenoid right below it. For nice packaging. Cons are closer to radiator, and not as spread if that's makes a difference, figure it has plenty of time before throttle body to mix up with the air.
thoughts??
Old 10-28-2016, 07:34 PM
  #226
Schnitz's Avatar
Yes sir. Slow and steady though.
https://ls1tech.com/forums/conversio...rbo-build.html
Can you put the nozzles just a little more upstream but after the BOV?
Personally I very seldom consider the way something looks. As long as it works have at it.
Old 10-29-2016, 09:41 AM
  #227
slocaddy's Avatar
They actually are upstream/after the bov, but I'm thinking more of on the inside radius of the pipe, when looking at snows pic of running multiple nozzles, they are spaced very far apart, so this should be fine
Old 10-30-2016, 03:20 PM
  #228
slocaddy's Avatar
So I took the hood hinge back off to show the turbo in one pic for everyone's viewing pleasure
Old 11-01-2016, 07:06 PM
  #229
slocaddy's Avatar
Workin on this right now=)
Old 11-01-2016, 11:36 PM
  #230
slocaddy's Avatar
A friend welded the bungs in for me tonight, repainted all charge pipes tonight, will install tomarrow
Old 11-01-2016, 11:55 PM
  #231
slocaddy's Avatar
Figure i might as well post my pcv stuff as well, it's a subject that confuses the shut out of me, I think I might need to switch to a sealed can, but I think I have something that will work
Mainifold pluggee
Old 11-02-2016, 04:22 PM
  #232
slocaddy's Avatar
Well, caddy does meth.
Second stage is wired in, just need another nozzle and tee
Old 11-02-2016, 10:47 PM
  #233
sweet99ss's Avatar
Hmmm makes me think about doing some meth myself... Good work just about done!
Old 11-02-2016, 11:14 PM
  #234
slocaddy's Avatar
Thanks! I actually ordered the last couple fittings tonight, I think it will look pretty cool with e nozzles in a row
Old 11-03-2016, 07:00 AM
  #235
Schnitz's Avatar
Movin' quickly. Nice!!
Old 11-03-2016, 04:03 PM
  #236
slocaddy's Avatar
So here's a finished trunk pic, prob do a sheet of aluminum that's removable, or maybe something clear and lit up lol
I added a charcoal canister because I don't want to deal with raw gas fumes should work out.in dealing with htdroboost/steering issue's right now it works , brakes will throw you through the windshield, but steering should be better
Charcoal canister
Old 11-04-2016, 06:23 PM
  #237
slocaddy's Avatar
So not a very exciting day but a productive one, apparently the hydro booster I pulled out of the junkyard a few years ago was no good. So today I modified the one that came out of the donor van to fit my car and now I have brakes and steering again
Another thing I did today was at the 1x1 blocks to get it further off the firewall to get the pedal height inside the car back to what it was stock plenty of pedal travel still
Positive feel, throw you through the windshid=)
Old 11-05-2016, 06:09 AM
  #238
rwb
rwb's Avatar
But when you are laying on the hood or the street, the car will look good!
Old 11-05-2016, 08:05 AM
  #239
Bad Apache's Avatar
I've said it before and I'll say it again. This car is just plain cool! Having good brakes and steering is critical in a 4000lb+ vehicle. Great work seeing it through!
Old 11-05-2016, 01:08 PM
  #240
slocaddy's Avatar
Ohyea!
Quick Reply: 1970 caddy sedan deville(sinister) lq4 s475 turbo cam=)
