Ls1 rails returnless rails for turbo 5.3
Old 03-02-2017, 07:38 AM
sean byrd's Avatar
Default Ls1 rails returnless rails for turbo 5.3
Did a search and didn't find an answer. I've got stock returnless Vette rails and am doing a turbo 5.3. I already have the sd 60s for the ls1 intake. Do I just add an aftermarket fpr or would it be easier to get different rails?
Old 03-02-2017, 10:27 AM
Restricted User
JoeNova's Avatar
Just add a regulator before the rails.
Old 03-02-2017, 10:36 AM
sean byrd's Avatar
Do I not use the Vette filter/reg set up with this?
Old 03-02-2017, 11:08 AM
Restricted User
JoeNova's Avatar
You can if you want to..
Old 03-02-2017, 11:42 AM
sean byrd's Avatar
Can you give more details? If I use the vette filter/reg setup with these rails do I not need an aftermarket fpr or should I ditch the vette filter/reg and get a fpr that is boost referenced for my setup?
Old 03-02-2017, 12:47 PM
Restricted User
JoeNova's Avatar
Would probably be best to get one that is boost referenced.
Old 03-02-2017, 01:14 PM
sean byrd's Avatar
Ok so If I get an aftermarket fpr then I don't need the vette filter/reg to be clear?
Old 03-02-2017, 01:29 PM
Restricted User
JoeNova's Avatar
Yes, If you buy one regulator, you don't need two.
Old 03-02-2017, 02:25 PM
sean byrd's Avatar
Did some more searching and found that you previously had a returnless rail set up. Is it a limitation in a boosted setup? Sounds like it may be easier to ditch these and get a return rail setup?
Old 03-02-2017, 03:51 PM
Restricted User
JoeNova's Avatar
I'm still running a returnless rail. No issues with fuel supply or runaway fuel pressure.
Old 03-02-2017, 05:11 PM
sean byrd's Avatar
dod you place your fpr near the rails and how much boost do you run?
Old 03-02-2017, 07:37 PM
Restricted User
JoeNova's Avatar
It's hard mounted to the rail with AN fittings. I didn't have fuel issues until 24 PSI but I wasn't even boost referencing the regulator at the time.
Quick Reply: Ls1 rails returnless rails for turbo 5.3
