Ls1/ls6 parts
Category: Accessories
Price: $1
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V, 67-92 Chevrolet Camaro, 67-92 Pontiac Firebird, Front wheel drive vehicles
Location (State): IA
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6, LT1/LT4, Small Block, Big Block
LS Engine?: Fits LS Engine
Pm or text with questions/what you need, offers, etc. Some prices might be a little high because I wasn't sure, so if you don't like it, make me an offer. I'll get pictures when I can get back out to my shop.
319-210-9684
Block- stock bore LS1. Cylinder walls are clean and scratch free. Would recommend a honing at minimum just to be safe- 500
Crank- stock, needs ground. Has a bad rod journal. Not sure about main journals yet. - 100
Rod/pistons- stock, have ARP rod bolts- 30 each
Cam- 227/234, .624"/.576", 113+2 LSA, 1000 miles- sold
Oil pump- Melling 10296, high volume high pressure, 1000 miles- sold
Timing set- LS2 chain, LS1 gears, 1000 miles- sold
Covers- valve covers (50), front and rear (25 ea), valley plate (30). All are painted red but some of the paint is chipping.
Lifters- Morel 5315 hydraulic rollers. 1000 miles.- sold
Pushrods- Comp Cams Hi-tech, 7.4" long, .080" wall chromoly. 1000 miles.- 60
Rockers- stock LS1 with Comp trunnion upgrade. Trunnions have 1000 miles.- 150
Heads- stock port 243s, decked .006", 3 angle valve job+ valves ground, pressure checked for cracks, new seals, .660" lift dual Comp springs, 1000 miles.- 800
Head bolts- ARP hex head, 03 and older blocks, 1000 miles.- sold
Intake- LS6, complete with throttle body, rails, injectors.- sold
Headers- fbody pacesetter 1 3/4 longtubes, 3" collector, heat wrapped.- 200
Crank pulley- stock LS1 fbody- 75
Stock LS1 flywheel - 75
