Aluminum 441 build on corn
Old 05-14-2017, 07:47 PM
  #81
BennyB's Avatar
Old 05-14-2017, 07:48 PM
  #82
BennyB's Avatar
Going to try and get pushrod length measurements and PTV clearance
Old 05-14-2017, 11:45 PM
  #83
Tuskyz28's Avatar
Badass Benny!!
Old 05-24-2017, 07:39 AM
  #84
BennyB's Avatar
Originally Posted by Tuskyz28
Badass Benny!!
Thanks man!
Old 05-24-2017, 10:18 AM
  #85
64post's Avatar
Benny, it looks like you ended up with a TH400 vs. the glide that you had planned for.
Old 05-26-2017, 09:04 PM
  #86
BennyB's Avatar
Yeah I did, that's just the way things ended up working out. I also got a nice deal on a whole th400 swap.
Old 05-27-2017, 09:54 AM
  #87
64post's Avatar
It'll work just fine and probably last longer. The down side is that it weighs more and uses a bit more power.
Old 05-27-2017, 08:55 PM
  #88
BennyB's Avatar
So I measured my pushrod length and came up with 7.905" at zero lash. My total length with .035" of preload would be 7.94". I suppose depending on who I go through I'll either need that measurement or minus .017 for gauge length. I'm debating between Manton or Trend and if I remember right one asks for gauge length and the other requires overall length when ordering.
Old 05-27-2017, 08:58 PM
  #89
BennyB's Avatar
I thought these measurements seemed high, especially for how far the heads are milled. I did use the comp cams length checker, but measured that with a digital caliper. Everything should be accurate as I checked several times on both exhaust and intake side
Old 05-28-2017, 07:05 AM
  #90
BennyB's Avatar
Old 06-30-2017, 06:14 PM
  #91
BennyB's Avatar
Old 07-02-2017, 01:47 PM
  #92
cookseyb's Avatar
Great build but I gotta ask, What's with all the blankets, towels, quilts and rugs? I thought I was OCD for setting everything on rags and shop towels but you got me "Hands Down"... LOL!!
Old 07-02-2017, 08:01 PM
  #93
Received 3,155 Likes on 2,462 Posts
He's all about decorum.....
Old 07-02-2017, 09:18 PM
  #94
FormerVendor
pantera_efi's Avatar
Default Alt rpm
Hi Benny, yes looks good.
I am sure you know this, just good to ask what your maximum Alternator speed will be in RPM ?
Lance
Old 07-04-2017, 10:15 AM
  #95
BennyB's Avatar
Making some progress boys, hoping to have the car back on all fours this weekend!
Old 07-04-2017, 10:17 AM
  #96
BennyB's Avatar
I don't know I've just always used old towels and blankets for everything. Usually for when I'm laying underneath the car so I don't have to lay on bare concrete, but yeah I'm kind of OCD too... lol
Old 07-04-2017, 10:19 AM
  #97
BennyB's Avatar
LOL that's right
Old 07-04-2017, 10:20 AM
  #98
BennyB's Avatar
You know now after looking at it, maybe it's time to invest in a car cover...
Old 07-04-2017, 10:21 AM
  #99
BennyB's Avatar
Lance
That's a good question, I'll have to look more into it.
Old 07-04-2017, 02:04 PM
  #100
FormerVendor
Default PMG Alternator
Hi Benny, yes a know value if I new your MAX RPM ? (8000 ?)
My PMG Alternator should be finished (proto) in thirty days, with "beta" units is sixty days.
That is a 12K Max RPM Armature with embedded magnets. (N-52)
The CAD will be done by Casey Wegner, a team member.
Lance
Quick Reply: Aluminum 441 build on corn
