Twin turbo, holley dual solenoid,dual tial gates hook up
Walk me thru hooking up dual wastegates and dual silenoids for holley. Compressors source to bottom of each wastegates.Do i split the source or use each turbo for each wastegate? Need a diagram of how to route setup. Tial 38mm gates twin 7275 precisions and dual holley silenoids. Thanks
heres how i did mine. i made sure the two lines to the gates are the same length. not sure it matters much but it was just as easy to do that than to cut them different.
if you put the sensor in one gate, the other gate will read lower. you should put the sensor at the solenoid and make the lines to the gates similar length if you want both gates/turbos doing the same thing.
I thought about it more though, and I think it's just as good or better at the wastegate as long as the lines are equal between both gates and the valves.
Holley doesn't want two solenoids on a single output just saying when it comes to running two wg and trying to use two solenoids (not in dome control)
And trust me in dome control you don't need the dome sensor nor solenoids at the dome themselves
I run the solenoids in the car, which feeds a small damping tank also in the car. The dome sensor is installed here aswell
A single line runs forward and feeds both domes.
Well as you can see the stability and response
![](http://i152.photobucket.com/albums/s167/rotary1307cc/IMG_20170702_170736074_zpsdqpq7rjt.jpg)
Still confused over how to run this. Can some one draw a diagram? Pressure source is off each turbo that goes to lower port on each gate is about as far as i got. Do i run 1 of the top ports to a t and place dome sensor there?Do i t the other top port together and run to solenoid?Where do u get pressure source for selinoids at? Do i use the same source as the gates?
