Can I use this that is capped off during my install of Procharger as a "feed" for my manifold I am going to use for my Meth boost reference, boost gauge and ati race valve?
If not where can I do that would feed my block? I have seen lots pointing to random spots including brake booster line however i would think i would need a check valve before booster??
You can use that port and there is a small nipple on the brake booster port in the back of the intake manifold that faces the pass side of the car. You can plumb all of it together if you like.
Can you possibly post a pic of this nipple? This is on a 2002 WS6 so i am no sure where it is.
Yes I am running a PCV system. (Ordered a Mighty Mouse Catch Can per recommendations)
EVAP? I am assuming is still on the car and will remain. I have removed the smog system when I did LT install (and tuned codes out) I am using stock fuel system with pump and hotwire upgrade.
