Attached is an older picture of the trim on the front of my '02. I had bonded it back once upon a time with GM gel Adhesive. It has since come back loose.
How can I remove the ORIGINAL adhesive sticky tape and the GM adhesive i used"? If i were to re-tape or glue it down, there will still be a gap due to the old product being between the molding and the car.
can I use something like "Goof Off" to remove the residue left behind? I dont want to dink up the finish on the trim or car.
whats the proper product to use to re-stick this to the car?
thanks for the tips. I didnt realize how easy that molding comes off. I took it off and used WD-40 - worked great. will reapply tonight once i get the tape and adhesion promoter.
