Why 6.0s are so thirsty?
Old 10-06-2017, 03:32 AM
  #121
foxsl's Avatar
That was impressive
Originally Posted by big hammer
My 2011 non DOD 6.2 sierra was as good or better on fuel than any 5.3 I had. And WAY more power. Hook a trailer to it though and it'll get thirsty quick. That was still one of my favourite trucks.
4 door 4x4 with just a hyperjunk tuner
https://youtu.be/Sr5yFMN4gNw
Old 10-06-2017, 09:53 AM
  #122
Darth_V8r's Avatar
Originally Posted by Tuskyz28
Darth... do you think this setup will burn even more gas over s stock cube 6.0 ?
LQ block with stock bore but 4 inch crank
Stock truck intake
243 heads untouched with Ls6 springs
Long​​​​​​ tube headers (nothing big)
Small cam such as a 210/216
I​​​​​​ know stroke eats duration... so I'm thinking a 210 cam in a 402ci would be the same as a factory cam in a 364ci motor.
No, I don't think it will. I think it'll be about the same. Torquey **** also. The long tubes are a great idea too for low end torque, even though they're typically associated with top end power.
Old 10-06-2017, 09:55 AM
  #123
Darth_V8r's Avatar
My S10 went from a 4.3 (180hp) 4l60e @14mpg to 17mpg, Swapped in LY6 with LSA supercharger LS9 cam and Tr6060 6spd E85 and now guess I should be in the 550hp range(crank hp) and get similar gas mileage. I'm not complaining lol
Similar experience here. Mine went from the carbureted 2.8 getting 17 mpg to a iron 6.0 with LS2 top end getting 22 mpg at 4x the power on 30's
Someone mentioned the 6-speed auto -- i've never driven one, but I can imaging how much better that is assuming they addressed the huge 1-2 drop in the 60E
Old 10-06-2017, 11:41 AM
  #124
Bill00Formula's Avatar
I have a trailblazer SS (6.0 liter) that has stock 4.10 gears, about 4,500 lbs and averages around 15-16 mpg.
Old 10-06-2017, 01:24 PM
  #125
Tuskyz28's Avatar
What's your mpg towing your F body to the track ?
Old 10-06-2017, 02:26 PM
  #126
Darth_V8r's Avatar
Tusky, your PM inbox is full. FYI
Old 10-06-2017, 02:48 PM
  #127
Tuskyz28's Avatar
Problem fixed. Thanks for the notification.
Old 10-06-2017, 03:20 PM
  #128
LS1Tech Premium Sponsor
tech@WS6store's Avatar
One of my 6.0s putting in work.
Old 10-06-2017, 06:21 PM
  #129
kingtal0n's Avatar
So if you had a 6.0 or 5.3, and wanted a near-factory lift and slow lifter ramp for stock lifters on a camshaft with around 220* @0.050, more on intake mostly on intake,
what camshaft would you look for and acquire, how would this happen
Old 10-06-2017, 06:51 PM
  #130
Received 3,109 Likes on 2,424 Posts
That is some awkward phrasing kingalOn, put it in a simpler format, please. I have a feeling your question is simpler than it appears.
Old 10-06-2017, 06:58 PM
  #131
He means a 220/220 479/479 on whatever lsa.
That would be a very ridiculous cam. Not even worth buying.
Old 10-06-2017, 07:07 PM
  #132
This is what JUST lift does
TSP Stg3 low lift
TSP Stg3 high lift
Ill try to get an actual overlay to show the diff.
Thats not even full tuned amd wrung out either with a richer afr than most would run.
Old 10-06-2017, 07:17 PM
  #133
Got that right! LOL
Old 10-06-2017, 08:12 PM
  #134
kingtal0n's Avatar
Actually what I am thinking is something with enough lift to be compatible with a PAC1218 spring, to take full advantage of any additional lift above factory possible using the OEM lifter but also not quite the maximum. Lets say 50 to 75% of the max allowable lift possible using OEM head/lifter. I just start at the bottom (Lowest possible lift) and work the way up.
Then, dont forget mostly on the intake side. so like 228/220
Old 10-06-2017, 08:21 PM
  #135
Our high lift hot cam does that. But imo the power band isnt made for a truck or towing.
This is the TSP 220r
Exactly what you're asking about. Note the torque peak. The higher duration you go normally moves peak power up so to speak and isnt made for towing. Even trying to use a more narrow lsa youll increase overlap and do the same thing.
Old 10-06-2017, 11:40 PM
  #136
Tuskyz28's Avatar
That's awesome!! I want more details on the motor, tranmission etc.....
Old 10-06-2017, 11:57 PM
  #137
04 2500hd 4x4. 6.0. Cai, efans, tune. nv4500 trans. Stock clutch.
Thats it. All together that load was just shy of 21k lbs. hauled it 5 hours one way. The tires made a HUGE diff. Some very nice 10ply Continental hwy tires. Got it up to 75 on the interstate also. Lots of hills too. No issues and ac on the whole time.
Old 10-07-2017, 08:47 AM
  #138
CattleAc's Avatar
Dog says..."I don't want anything to do with that load on a single wheel 3/4 ton"...
Old 10-07-2017, 09:46 AM
  #139
He was chasing a frog. I had no issues. That was 3 years ago. That is the heaviest ive hauled in quite some time but i have hauled more with that truck and trailer combo. Most of the time its way less. My white 05 xcab 4x4 has hauled 17k worth of hay a couple times a year on 4 hour trips to my ranch also.
I have an all steel car hauler also i use for many chores besides just hauling cars around as well.
Im no hot shot or expert by any means, but ive been doing it so long i can tell you the capabilities of em.
Both will be getting 370s likely with some other upgrades soon. The 5spd manual is by far the best for heavy loads but the single cab sucks for it so its a trade off. That gooseneck trailer alone weighs ALOT.
Old 10-07-2017, 11:29 AM
  #140
Darth_V8r's Avatar
TSP Stg3 low lift
TSP Stg3 high lift
Yes! If anything building for torque you’d want high lift short duration. Like the XER lobes almost. Or like you suggested in tbecstealth thread, high ratio rockers
Quick Reply: Why 6.0s are so thirsty?
