2008 corvette f1a procharged 408 e85
Year: 2008
Make: Chevrolet
Model: Corvette
Price: $28000
Mileage: 87000
Location (State): KS
Color: Black
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
![](https://cimg4.ibsrv.net/gimg/ls1tech.com-vbulletin/600x450/db289cc5_bdf3_47d9_8e8c_b0b948b11e48_c2a499ab870b15a32d4dd39b565434474c200c90.jpeg)
![](https://cimg5.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1111/5e64231e_970b_4c45_bc58_75e996b58ca9_f738ce7a77a30ae6d23fb0f21aa2125aa345e238.jpeg)
![](https://cimg6.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1786/cacba22e_1ab5_4568_aac1_dfe8ffe132ca_9af22ee4fdab3fef1c0089a2d9c7b3b8b61845bb.jpeg)
![](https://cimg7.ibsrv.net/gimg/ls1tech.com-vbulletin/720x480/912e7456_367e_4b22_920c_11009f26900b_87044ce88b60b987ee7cc494f6a49fa64e88d2b2.jpeg)
![](https://cimg8.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/37d19200_b3ae_4305_a81d_e3cc22dc3e4f_fe32b9901de60a1ec92fa2d033e50867201d57ff.jpeg)
![](https://cimg9.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/94f3b18d_d8de_4c2b_b0fc_b419664bf52d_b05c603a2465ec2dfd49deb6754e575473cdaaf7.jpeg)
It’s an 08 87k miles has a 408 Manley rotating assembly ls3 Heads btr custom grind blower cam motor has maybe 4K miles I have the paperwork for the short block, ict billet intake, has Hinson long tubes an x-pipe with factory npp mufflers, a&a procharger kit so it has the bigger intercooler an a&a turbo smart bov the f1a was new from procharger in April it has maybe 200-300 miles on it. Has the innovators west 8 rib swap on it. Has alky control meth kit, on the fuel side it runs the stock pump with a boost a pump an fuel line during normally driving, then under boost it kicks on 2 aem 380 in-line pumps with there own -8an feed car also has a-6 return on it, Bosch 127lb injectors. Has a tr6060 with an rxt clutch, I run ams oil in the trans am rear diff, it has zo6 replicas 18s in front tires have maybe 1k an 17s in rear with a 305/45r17 mickey et street r drag radial. Has a aluminum radiator. Interior there some normal wear on the driver seat, has the centennial alcantara center console Iid steering wheel shift boot and shift ****, has lloyds floor mats kenwood double din an factory carbon fiber center console, auto meter pod with aem boost gauge an aem wideband. Heater works great and the ac blows could. The lingenfelter hood I got in trade to clear the intake an charge pipe need some work I just threw it on so I wouldn’t ha e to cut the stock hood which it will also come with the factory hood. I’m sure there more stuff I haven’t though of. Would trade for a built 4th gen with cash on top on your end 28kobo
Car has a 4.25 pulley right now which is good for 17-18psi an it’s just over 1000whp. The blower isn’t at max rpm so you could go to a 4.00 pulley an make a little more if you wanted. I did all the work to the car an it was tuned in Kansas City at kcmaxx
did you said tge car made just a 1000whp or the pulley is good up to a 1000whp? The car was too nice n i got brain dead reading it. Too much want here.
very nice car, I have a 99 Camaro black with the same rims, just built a 370 with manley H beam rods and wiseco pistons, trick flow 215 heads and a customer built rear mount turbo kit, motor has like 15 miles on it. would like to see if you are interested in doing some trading, car has a lot of other stuff done to it will explain if you are interested.
the car had a stock bottom end 5.7 and made 680whp on 14psi, broke a ring land and built a 6.0 .030. just got car back together and I havent even tuned it yet. has a 4L80 trans and FIC 3800 convertor, stock 10 bolt with auburn posi and aftermarket axles, 3.42 gear, brand new turbo tubular K-member and lower tubular A-arms, leash boost controller AEM wide band, stock interior, all A/C and heat still on car and work just have to charge A/C it was drained for engine swap, LS2 ported intake, fast 80LB injectors, 90 Fast throttle body, Kooks full tube 1 7/8 headers, yella terra roller rockers, brand new cam 233/239 texas speed cam on 112. MSD 2 step and I have a brand new lingenfelter 2 step retard box I haven't installed yet, also have a brans new jakes trans brake 1050.00 still in box. car has nitto NTO5R on it now and I have a set of mickey Thompson drag radials to go with it maybe 50 miles on them. 450 in tank fuel pump, CO2 bottle for boost controller, car should make around 800whp when tuned will need better fuel system to go more. the caliper are now black and so is the grill. also has subframe connectors and adjustable lower control arms and aftermarket adjustable torque arm. It has a comp 78mm billet wheel oil less turbo, 66mm turbonetics wastegate, me and a friend made the turbo setup.
I have a 02 SS NBM Coupe with True Black Interior has 6 Speed built by LINGENFELTER PERFORMANCE it has 40XXX miles on it! Dynod at 477.3RWHP has stage 3 ported LPE heads LPE Cam Ported intake! Moser 12 Bolt with 3.73s trutrac only 1500 miles on the Rearend TSP True Duals with bullets Has a custom 3inch Driveshaft, Kenny brown subframes BMR Torque Arm Has 19inch RUFF Racing 278s Hyperblack all around! I put about 3000 miles on it in the last 5 years it doesn't get driven that often I can send pics to your phone if you want to check it out? Thanks. Benny
