water pump mechanical fan, threaded mount
Old 02-02-2012, 12:36 PM
ls1_chevelle's Avatar
Default water pump mechanical fan, threaded mount
When pulling the mechanical fan off say a truck water pump pulley. Can a guy cut the remaining mounting stud for the mechanical fan(that it threads onto)? I took a look at it and I can't see why not?
Old 02-02-2012, 01:27 PM
frojoe's Avatar
Only reason I see that you might not want to cut it off is if you want to thread a puller onto it to push it off of the waterpump shaft, but then again you could just use a 3jaw puller to remove the pulley. From the pics I have it looks like the only purpose of the threaded snub is just to hold the clutch on there.. I say go for it. Are you running out of room for fans? My big single electric fan had the motor's housing come about 1/2 away from the truck waterpump threaded stub before I switched out to the LS3 waterpump.
Old 02-02-2012, 06:12 PM
Just to clean it up really. I'll cut it off. All I use is a 3 jaw puller aswell. Just figured I'd ask incase I was missing something.
Old 01-22-2018, 09:28 AM
waid786's Avatar
Resurecting very old post.
I need to install Dodge Intrepid fans and its going to be very difficult without cutting the radiator core support in the S10.
I don't know how much material there is behind the threaded part that is pressed in. I would love to cut the tip off to make more room.
Did you end up cutting the threaded tip ?
Thanks
Old 01-22-2018, 09:57 AM
33willys's Avatar
Default water pump
An LS3 water pump will bolt to a Gen III block?
Old 01-22-2018, 10:24 AM
waid786's Avatar
I don't think this cannot be done. I could not find any picture but did find a YouTube video of LS water pump tear down. The tip is part of the pressed on part and if it is cut and removed, very little surface would remain of the pulley that would be pressed and may come lose.
Waid
Old 01-23-2018, 09:09 AM
Michael Yount's Avatar
Having dealt with the problems associated with a lack of space at the front of the motor for a long, long time (swaps) -- I'd take a hard look at spending the time to move the radiator forward. Over the long run, you'll be glad you created the extra space.
Old 01-23-2018, 09:39 PM
S10xGN's Avatar
I was able to stick a mid-80's C4 radiator in my S-10 after cutting the core and gained 2". Still have A/C and a front-mount intercooler ahead of it. Pulling it apart is easy...
Old 01-29-2018, 02:21 PM
waid786's Avatar
Did you have to move the AC condenser at all?
waid
Old 01-29-2018, 04:49 PM
S10xGN's Avatar
waid
I'm pretty sure that's in the stock location, just that the core was cut out just enough to push the rad inside the core. E-mail me and I'll send you the pix I have of it.
Quick Reply: water pump mechanical fan, threaded mount
