What did you do to your V today?
#1983
- Not today, but forgot to share this one a month or so ago. Nice dent on the top of the driver side fender - someone dropped something pretty heavy on it while it was sitting in a lot on the Army/Marine base for a few weeks. Dent is probably ~6" long; fortunately it's not on the crease at the top of the fender, so maybe a PDR pro can take care of it. Haven't looked into that yet.
#1984
Cleaned my new to me volant Cai that made the journey across the pond.
Doesn't add power. I didn't expect it to .It does however allow me to pass the inspection for my modified car registration .
It does rev much freer and under part load it revs as fast as at idle. Very happy with the setup.
-Byron
#1986
got me a roll of 1in i.d. insulated heat shield tubing for the alternator wire (and fuel line on the t/a) and got me a new dei battery blanket. hopefully it will not cook as fast would like to avoid the battery relocation to the trunk.
#1989
Got the break in gunk flushed from the new trans. Drain and filled the 8.8 with ford racing oil 75-140 plus 4oz additive .
Fixing a clearance issue with the exhaust so it will quit tapping on the subframe.
-Byron
-Byron
#1990
My CTSV's Diff got some new fluid today during lunch , and some fresh oil for the engine!
Update:
Used Mobil 1 LS oil in the diff and my rear gear is QUIET. It sounded like I had bad hubs since I've owned it. I hope it stays like this.
Update:
#1991
Took the car, bad DSS axles and all and flogged it all the way up Jebel Jais in Ras Al Khaimah yesterday.
Spent some quality time with the misses and got some fresh air. The tranzilla is absolutely straight beast and smooth as glass.
-Byron
-Byron
#1992
Ahh the upside down lower grille, that brings me back.
I changed my oil because i either popped a head gasket or because my car is a garage queen and is rarely ever driven hard lately, there was water in the oil. yay.
#1993
-Byron
#1995
How much water? Coffee with cream and sugar look or worse? Cream and sugar is not too big a deal
#1996
Just changed my trans fluid. I believe it was a 22MM wrench for the temp sensor for those without an American wrench handy. Then I filled it with Pentosin FFL-4. I know, not d/m III. This was recommended by an appropriate source. Any issues and I'll post. It shifts nicer than before
At 65k miles I have fresh:
GM cold climate PS Fluid
Mobil 1 gear oil
Fresh fluid in my clutch hydraulics - amazing difference in pedal feel.
Fresh transmission fluid
Next is:
replace buttons on radio and screen
Repalce tail shaft seal + check the carrier bearing
dream of headers....
Mobil 1 gear oil
Next is:
#1997
Mobil 1 gear oil
Next is:
Mobil 1 gear oil
Next is:
Drove mine yesterday, nothing much to report during winter.
#1998
Yup. Minor updates while keeping it healthy. today I protected my passenger backseat from my little guy.
these are available from your local Audi Dealer...
#2000
Got my creative steel trans mount in. Stock mount was definitely bad, but now it feels like my motor mounts may be shot. Going to order those.
This weekend I will be doing new brakes front and rear, will have a review on the duralast gt pads. Also got my threaded stick and creative steel shift ball to install.
