ProCharger Front Mount Intercooler for 98-02 F Body
#83
Honestly if your under 600 rwhp I wouldn’t bother losing the 4.5’s. I’m over 750 and went to a cx front mount (both setups with alky control and 93 tune). I was seeing 150 iats at the end of the half at wannagofast in cool air. I’m going to make a spoiler to jam more air in and see what that does. Since I’m running a formula I only have the license plate hole right now. Can’t yank the fog lights like a ta.
If I dont like the spoiler results it may get an a2w or a garret/bell cored a2a. Bob will eventually respond here and is a great help. I don’t know how good the pc fmic really is by comparison. I kind of wish I had kept all my stuff and went to twin small a2w that mounted the same.
All hypothetical though since I’ve resisted going water because of that new headache I’d introduce.
Still haven’t mastered an air filter system I love. This car is a continuous pain I can’t seem to quit on
#84
Still haven’t mastered an air filter system I love. This car is a continuous pain I can’t seem to quit on��
Flaps under your intercooler should lower your iat's since you have a limited opening in the nose. It's been done before and it makes a real difference.
The ProCharger front mount intercooler is superior to the CX Racing intercoolers. At the old EPP shop we sold front mounts using a CX Racing intercooler, this was prior to ProCharger coming out with a front mount for the 4th gen. The CX Racing (Ebay) intercoolers are a hit or miss deal, some of them seem to flow okay, others aren't worth a crap. One customer, Brian K had a CX Racing intercooler on his GTO, he kept having problems with it, and bought a ProCharger front mount from me which solved his problems. I'm going to e-mail him and let him know about this thread to see if he wants to add his input.
As far as going to an air to water, I think you'll regret it if you do. I found it to be a pain in the rear on my Camaro. I sent through a lot of bags of ice at the track and the inlet air temps weren't getting low enough to make it worthwhile. Bob
#85
Maybe I'm just being silly, but doesn't adding a spoiler to force additional air up and into the engine bay mean more lift? Seems like that could be a concern at the high speeds you're going to be seeing running 1/2 or full miles.
#86
Nope, spoilers under the front add downforce. Bob
#88
Need the air through the radiator as well anyway. HP generates a lot of heat so not an issue. Bob is right about the A2W which is why I have resisted it.
I think my CX is OK but if the spoiler doesn't make me happy, I'll be buying a high quality IC
#89
Left off something. Keeping air out of the bottom of the car is a bigger help and a lot of the air you are thinking is gathering in the engine compartment is actually diverted to the sides as well which creates a lower pressure under the car which helps air through the IC and radiator as a bonus. My car isn't as low as it should be because I want it to work better on the launch and not be a victim in and out of the driveway or speed bumps. Everything is a compromise as always.
#90
Yes, it replaces that one. That picture is of a twin intercooler setup. Air is coming into the box from two separate IC's and then is directed to the motor. With a front mount you can use that box/plenum.
#91
The race bypass valve is a ProCharger bypass valve (big red) that is much larger than the standard ProFlow bypass valve. Basically it is needed at 12+ psi of boost, so that boost doesn't stack up and try to slow the blower down when the throttle is slammed shut. The race bypass is also a lot louder, many people order it for this very reason, even though they're only running 8 psi. Bob
#92
The cost for a very good FMIC is about the same it seems.
If you don't go with the Procharger unit, the 6" Bell or 4.5" Garrett are about the same (and a 6" Garrett is going to perform the best and be the most expensive).
#93
Yes it does. Here's a link to it. http://shop.brutespeed.com/ATI-1GJ11...-1GJ115-IC.htm
#94
I know is an old thread but just doing some research before I'm that guy that asks a question that's been asked several times on here...does anyone have any examples of this spoiler or flap to aid more air to intercooler??
#95
