Foxbody notch lq4 turbo build
Old 12-27-2017, 07:38 PM
  #101
Lsxnafox's Avatar
Mounted the fuel rails today on the the intake. These are from Holley ment for the ls1 intake. I was going to make some brackets to hold them down, instead I was able to use a bolt going up through the bottom of the intake mounting hole and the brackets that Holley supplied.
Old 12-27-2017, 09:10 PM
  #102
dmracing's Avatar
Those fuel injector spacers suppose go on the bottom of the injector?
Old 12-27-2017, 09:23 PM
  #103
Lsxnafox's Avatar
That's how I got them. They are fic 127s.
Old 12-28-2017, 04:53 AM
  #104
Burning's Avatar
Originally Posted by Lsxnafox
Couldn't use the threaded rod to secure the pumps. They have to sit at an angle so the hose won't kink. The plastic piece that the stock bucket sits in does the job of holding them from moving around too much.
-6 adapter on the stock feed for the return fit on I re used it from the factory fuel rail I was using for fuel supply.
What are you going to do about the two holes you had from the previous mockup?
Old 12-28-2017, 07:59 AM
  #105
Lsxnafox's Avatar
I used some pieces of solid rubber I had laying around and plug up the holes along with some epoxy.
Old 12-28-2017, 08:51 AM
  #106
Burning's Avatar
I would drill some holes in the basket to ensure that you dont run it dry while under fuel throttle. Just my .02 , I love the build though. Been trying to track down a reasonably priced notch for a while, if i ever come across one ill just rip the guts out of my 04 and drop it in... Gotta love AJE lol.
Old 12-28-2017, 09:12 AM
  #107
Lsxnafox's Avatar
Thanks!!! It's been a fun build, I'm even surprised how far the car has came along. It will be two years in April since I got this car as a stock 4 banger and soon it should be making close 900 wheel.
I'm just gonna use this setup for the Dyno. I really didn't spend much on modifying the hat so wouldnt be much of a loss. Before I do any track runs I'll try and find a baffled tank along with a tripple pump hat. I don't want to risk going lean and burning piston just for trying to save a few hundred bucks.
Old 12-28-2017, 01:40 PM
  #108
Mungface78's Avatar
Have you checked out Glenn's performance tanks?
Old 12-28-2017, 01:46 PM
  #109
Lsxnafox's Avatar
I haven't yet, I was thinking of finding a 03/04 cobra tank. They come from the factory with a baffle.
Old 12-29-2017, 06:13 AM
  #110
Burning's Avatar
Thats what im hunting for right now. Seems like i can find them for around 500 on ebay, I think thats a little steep.
Also along with the stock baffled setup it has a dual pump hat!
Old 01-03-2018, 06:48 PM
  #111
Lsxnafox's Avatar
Got the fuel system all wrapped up. Engine bay looks like a damn birds nest. There's hoses and lines running everywhere seems like. 3 of the fragola 90 degree fittings are leaking. They are connected to orb fittings from Earl's figure the mismatch must be the cause. Ordered some earls fittings. Strange though two 180 degree fittings are fine.
Old 01-15-2018, 12:53 PM
  #112
Lsxnafox's Avatar
Just couldn't stand how cluttered the engine bay looked with the truck manifold. Got a alternator relocation kit from ICT billet and already had a ls1 manifold and water pump.
Old 01-16-2018, 04:23 PM
  #113
Lsxnafox's Avatar
Much cleaner with the ls1 intake.
Old 01-17-2018, 08:23 AM
  #114
Gunters96lt1's Avatar
looks good man!
Old 02-15-2018, 10:55 AM
  #115
Lsxnafox's Avatar
The little factory foxbody 4 banger drive shaft held up long than I expected. I'm gonna start making some real power so upgraded to the larger 1350 u joints and rear end flange.
Chromoly sonnax 4l80e slip yoke. This thing is a beautiful piece.
Old 02-22-2018, 09:48 PM
  #116
Lsxnafox's Avatar
Got the car back on the Dyno. Motor ran great made 753hp and 700tq on 14 psi with only 16 degrees on timing. We stayed on the conservative side until I build the rear end. Can't wait to get some track times.
Old 02-23-2018, 05:56 AM
  #117
Stampede4ever's Avatar
What cam, heads, and turbo are you running? That Fox is going to hurt alot of feelings.
Stampede.
Old 02-23-2018, 07:39 AM
  #118
Lsxnafox's Avatar
Stampede.
Stock 317 heads with pac springs and a comp cam 230/230 with .570 lift. 76/68 turbonetics turbo.
Old 02-23-2018, 08:01 AM
  #119
408GT's Avatar
Maybe lost a couple hp with tire rub? haha
Old 02-23-2018, 08:43 AM
  #120
Lsxnafox's Avatar
Lol ya I lowered the rear a bit and it was catching on the rear lower part of the wheel well. Gonna have to do some cutting .
Quick Reply: Foxbody notch lq4 turbo build
