Stock bottom 4.8, 4l60e, 10 bolt and BOOST Build - Complete - PICS
Old 03-08-2018, 12:44 PM
"I MAID THEESE"
Mavn's Avatar
Default Stock bottom 4.8, 4l60e, 10 bolt and BOOST Build - Complete - PICS
Heres some pics I snapped along the way of my turbo Build. All done in House at my shop Hangman Performance Here in Houston . STock K member Turbo Build that will retain A/C. A/C is off because of TX2K Crunch. But here is is :
IG @Hangmanperformance
I'm not gpood at this documenting thing. Let me know if you have any questions!
Old 03-08-2018, 12:58 PM
svslow's Avatar
Is that 565whp at 12psi?
Old 03-08-2018, 03:22 PM
"I MAID THEESE"
Mavn's Avatar
Yes sir!
Old 03-09-2018, 09:37 AM
laytoncamaroz28's Avatar
Sweet build and hot pipe setup man! Where does the dp go to the back?
Old 03-11-2018, 05:54 AM
forcd ind's Avatar
Always cool to see power from the small engines, good job.
Old 03-11-2018, 07:02 PM
ddnspider's Avatar
Info on what had to be moved or relocated would be cool. Is the DP above or below the stock K?
Old 03-14-2018, 10:53 PM
WTF?'s Avatar
Which converter and gear, Please?
Old 03-15-2018, 09:39 AM
"I MAID THEESE"
Mavn's Avatar
Circle D 3800 Single Disc
3.73's
Old 04-13-2018, 06:59 AM
merim123's Avatar
Can we get a little more info on the hotside. which passenger manifold did you modify? I'm having a hard time visualing how that big loop on the passenger side can actually clear in an fbody, did you have to mod that at all?
Also as others asking, where does the DP go, since you move the alternator, looks like you have it setup for Drivers side?
Old 04-13-2018, 09:50 AM
"I MAID THEESE"
Mavn's Avatar
DP goes up and out the hood right now for fun. setup for Going pout Drivers side. That Loop tucks up nicely under the car. I have some pics ill attach
Also Went back to the dyno and Laid down 650 rwhp Slipping the converter 25%.. Lol so a new converter is ordered. that was on 18#
Old 04-13-2018, 10:24 AM
red fury's Avatar
Well done hot side! Turbo location is nice too .
Old 04-13-2018, 10:37 AM
red fury's Avatar
Couldn't the alternator go back to the stock location?
Old 04-13-2018, 10:49 AM
"I MAID THEESE"
Mavn's Avatar
Yes it could. But its getting a down pipe out that side so we went ahead and put the alternator up top
Old 04-13-2018, 10:53 AM
merim123's Avatar
thanks for sharing the pics. is that a stock passenger manifold or off of something else?
Old 04-13-2018, 10:55 AM
"I MAID THEESE"
Mavn's Avatar
I cant remember .. Its either a GTO or a truck or a CTS. lol
