Just installed 2.9L whipple on LQ4, a couple of questions
Hi All
I have a 1973 Camaro that I'm doing a LQ4, whipple, M6 swap this winter.
I just got my whipple and installed it.
My questions are:
I have a 102 mm Holley Throttle body. The TPS is hitting my top pulley. I was thinking about machining the side of the TB. Is there other ways to get the needed clearance?
Is there another spot to run my boost gauge to? I see a pipe plug in the drivers side behind the fuel rail. I figure that should have boost pressure there.
Is there a throttle cable bracket that I could get? I looked on the whipple website and didn't see anything.
Thank you.
Roman
My questions are:
Thank you.
Roman
On the DBW throttle body's u just flip them . I would send whipple an email. They might have a different TB or a spacer. What size pulley are u running? Your prob gonna want a 3.50 for around 12-13 lbs
I'm using a 90 mm DBW off an ls3. I bought the hotrod kit @ Camaro spacing. U just flip it upside down. What spacing are u running? Let me know if u need help with the accessory drive.
Simple fab solution to the TB interference issue:
Order two 102mm TB flanges and a short length of 4-4.5" alum pipe. Weld together for a spacer. That way the throttle cam can be flipped back to standard orientation. Cable mounting will be easier. If you're limited with space up front, you can incorporate a 45-90* bend into the spacer for the intake tract to clear whatever obstacles are up front
If you know a machinist, have him map out the bolt pattern of the TB flange and machine an adapter to rotate the TB 90*. This way the throttle cam is on top and the sensors have room on the bottom
Cable bracket isnt hard either. With a fabricated neck, you can weld a boss on to mount a 98-02 Fbody bracket or design your own. Holley makes a sandwich style that goes between the TB and TB flange hanging rearward
On my 2.9 the connections on the back of the blower are for IAT and MAP sensors. If you change the MAP sensor and calibration and have a gauge that can capture that signal you're good to go. If you have a gauge that requires an actual pressure reading it has to come from somewhere else.
Thanks for the idea!!
Mines a 2016 Silverado 5.3. The IAT came preinstalled and the stock MAP sensor installs right next to it. Don't remember seeing another plug back there but maybe I missed it. Where is it relative to the other sensors?
![](https://cimg4.ibsrv.net/gimg/ls1tech.com-vbulletin/1500x2000/img_1303_63eac675ee9f94892ce3f2c826a75bcd17be1e8e.png)
This is from the Camaro instructions found online
