OFI results
Old Apr 24, 2007 | 04:44 PM
  #61
cablebandit's Avatar
oh lawd Al...i am thinking bkr7e
Old Apr 24, 2007 | 04:47 PM
  #62
kp's Avatar
kp
Originally Posted by cablebandit
ahh...the -8 ngk didnt foul...just idled rough. Also when it was cold and tranny went into lockup, it would misfire. tr6 fixed that so i am gonna try in between i think...i got the 3923 from one of your posts and thats what i have now but i THINK its the same heat range as tr6...if its closer to a -7, ill keep them...time to go plug reading on the net
3922 is like a -7 for your heads, 3923 is like -6 NGK. NGK and autolite go in opposte directions for heat range. I used the 3922s for a while and switched to the AR3911s (-8 NGK), both worked fine for me. Matter of fact I had 2 sets of 3922s in the trailer.
Lot of numbers for a lousy little spark plug
Old Apr 24, 2007 | 05:08 PM
  #63
ngk 7173 it is.....
Old Apr 24, 2007 | 06:15 PM
  #64
onfire's Avatar
Coal Mining Director
NGK BP7EFS stk# 3526 is one heat range colder than a TR6 and is the correct reach for a stock style head. It also has 1/2 of the "projected" tip of a TR6. My TR6's were fine at 17psi. BP7EFS should be fine for a street/strip 20psi car using stock style heads IMHO.
Old Apr 24, 2007 | 07:02 PM
  #65
NA$TY-TA's Avatar
Sweet..... Ill return the TR^'s i have just sitting here and get a set......
Kyle
Old Apr 24, 2007 | 07:24 PM
  #66
Got Me SOM's Avatar
great shakedown run! looks like you definitely have more in that combo. awesome! good thing it wasn't a real catastrophic failure.
Old Apr 24, 2007 | 07:48 PM
  #67
thanks!!!
Old Apr 24, 2007 | 11:08 PM
  #68
1QuickT-A's Avatar
mine did the same thing.. if the engine was cold or if it was cold outside it wouldn't run worth a **** until I got a good bit of heat in the motor.. it would misfire while driving and eventually they gas fouled..
 Michael S. Palmer
Old Apr 25, 2007 | 04:31 AM
  #69
I am going on Mightmouse suggestion as I know he drives his every day
Old Apr 29, 2007 | 09:42 PM
  #70
obZidian's Avatar
sooo.... let say im retarded and all of these numbers dont do for me, hypothetically speaking of course..
i have a set of tr6's that are gonna go in soon, since i will DD the car a bit, i dont want a plug that will suck on the street. The tr6 might be to hot, and the "tr8" is too cold... so a "tr7" is what i need. Since im running a 6.0L head, which one should i run then? The NGK BP7EFS stk# 3526 or the AR 3911's?
Man, all this plug talk is more confusing than trying to figure out cam events!!
Old Apr 30, 2007 | 05:03 AM
  #71
you saw my other post..i would say a projected/semi projected -8 ngk heat range.
Old Apr 30, 2007 | 09:56 AM
  #72
NA$TY-TA's Avatar
Im running 6.0L heads with the TR6's now.....
Ill be trying the
When i get back home this week.....
Ill prob be adding timing down low and up top for my race gas tune and ill let ya know....
Kyle
Old Apr 30, 2007 | 11:12 AM
  #73
onfire's Avatar
Ill be trying the
Kyle
I've been running that plug for a month now with no problems....changed from a TR6. Idles and drives great. Boost is up to 14psi and going to 18...fires well through a 10:1 tune as I lean it out with tuning passes.
Old Apr 30, 2007 | 12:10 PM
  #74
made some WOT passes on the street...track screen/filter installed with cutout open and new 11.6 psi spring. Boost held 11.8 psi so I am happy now. Onfire, i used what i thought was your setting of the eboost2...30=14psi...at least it worked that way for me....25=12.x psi
boostve table is set at 205kpa and above to 500...max efilive allows....that oughta richen it up if it were to overboost!
Old Apr 30, 2007 | 01:01 PM
  #75
ty_ty13's Avatar
7 Second Club
becareful of going too rich... it can cause crank and rod damage.... if it were to not ignite in one cylinder it coulb be bad...
Old Apr 30, 2007 | 03:12 PM
  #76
ill keep that in mind but in my experience...too rich just makes the motor lay down...I have hurt a lot of stuff but never from being too rich Ill keep your idea in mind though
Old Apr 30, 2007 | 06:46 PM
  #77
obZidian's Avatar
WOT on the street huh?
well, did it involve a smokey burnout as well?!
Old Apr 30, 2007 | 06:52 PM
  #78
onfire's Avatar
That's the correct settings, but they are PROPRIETARY and are only to be used by me.
Old Apr 30, 2007 | 07:35 PM
  #79
wot from about a 40 roll with MT DRs......i did chatter them for a few hundred feet but eventually they hooked!!
onfire...well it was originally your tune so i guess its ok for me to use those settings
