Billet Specialties Street Lites & Narrowed S60 PICS
Old 05-22-2016, 04:25 PM
91foxcoupe's Avatar
Default Billet Specialties Street Lites & Narrowed S60 PICS
Strange S60 (narrowed 3" per side)
Billet Specialties Street Lites 15x10 (4.5" BS) & 15x4 (2.25" BS)
Old 05-23-2016, 10:10 AM
Rise of the Phoenix's Avatar
Damn nice right there. Narrowed rears with deep dish drag setups look so good.
Old 05-23-2016, 11:15 AM
sillysspeed's Avatar
Nice setup! Looks great on your car. Very similar to mine. I got the blacks with the 17x4.5's up front
Old 05-23-2016, 12:46 PM
silverWS.6's Avatar
Those wheels are just amazing!
Old 05-23-2016, 07:48 PM
Champion makes some really awesome lug nuts and aluminum washers for the street lites. Lug nuts that come with the wheels are horrible. Start rusting along with the cheap washers.
Old 05-23-2016, 09:18 PM
BOLO's Avatar
I'm liking these wheels very much. I also have an S60, but narrowed only 2" per side. I will be getting them in 5.5" back spacing. Fronts will be their 15x3.5" 1.75"BS or 15x4 1.625BS.
Old 05-24-2016, 07:51 AM
abern310's Avatar
looks amazing! narrowed + deep dish
Old 06-04-2016, 09:27 PM
91foxcoupe's Avatar
Thanks guys.
Old 06-09-2016, 06:11 AM
BOLO's Avatar
Are you running 5/8" wheel studs? Strange axles? Very nice set up!
Old 06-10-2016, 10:06 PM
91foxcoupe's Avatar
Thanks.
Yes 5/8" studs & Strange axles. Strange Pro Series rear brakes also. The LT1 brake calipers wouldn't clear the spring/panhard mount with the 3" per side.
Old 06-10-2016, 10:22 PM
91foxcoupe's Avatar
Old 06-12-2016, 10:07 PM
BOLO's Avatar
Originally Posted by 91foxcoupe
Thanks.
That's one reason I had mine shortened only 2" per side while retaining the stock rear LT1 brakes. In fact, 2" per side is max if using LT1 brakes. Anymore will require their Strange brakes or swap to LS1 brakes.
Old 12-05-2016, 10:28 PM
Super Hulk Smash
JakeFusion's Avatar
Was looking for some good pics of these in 15x10 with the 4.5" BS. Awesome.
I'm thinking of doing this. Need more traction with the 15s.
What tire are you running? The 275/60s?
Old 12-10-2016, 06:41 PM
2JAWZ's Avatar
Looks really great, and hope it runs as good as it looks, but say one day your taste and intentions change and you wanna wheel swap,, what then, rearend swap??
Old 12-27-2016, 10:39 PM
GMRACER13's Avatar
Whoever told you that "fact" is wrong. Narrowed 3" per side and stock LT1 rear brakes here.
Old 12-27-2016, 11:46 PM
BOLO's Avatar
^^Good to know. But how did you clear the driverside bleeder screw without cutting the pan hard mounting bracket. Mine is narrowed 2" per side and had to shave the bleeder screw a bit, as you can see in the pic below. Going another inch would definitely be hitting the pan hard mounting bracket.
Old 12-28-2016, 09:39 AM
GMRACER13's Avatar
I cut a small notch in it just to clear the bleeder. Wasn't a big deal and doesn't affect anything. I also kept my stock parking brake. By the way, your car looks badass.
Quick Reply: Billet Specialties Street Lites & Narrowed S60 PICS
