Another destroked ls3
Alright if your another diehard stroker fan, please move along. Especially if your aunts cousins brothers son n laws uncle built a destroked Ls and didn't like it. If you have built one yourself I would like to hear feedback.
i recently built a all forged ls1 stroker with all the goodies Cnc heads arp all throughout. Built for nitrous. It just didn't cut the mustard. So I bought a Texas speed 6.0 iron block bored to 4.065 sonic tested ok. With it I bought mahle L92105065P25 pistons -25 cc compression height 1.105 as a package deal for $1400 (pistons alone were 1100) which was a score imo because everything was new. Now I'm going with an lr4 crank and the hard part was finding the correct rods. I'm pasting my notes from last night. Give me your opinion please
L92105065P25
Mahly pistons are suppose to have a 4.000" crank
With a 6.125" rod which produces a 416" 4.065 bore
We are using a 3.268"crank
So the difference between a 4" and 3.268" is .732 (difference in diameter)
Take .732 and divide by two to get your radius difference
Which is .366"
I believe radius is the main difference we are looking for when trying to configure the correct rod size.
So take a 6.125" rod and add .366 to get your new rod length
Which is 6.491
Tall deck LS engines have a rod that is 6.460 which would have the correct "on center" wrist pin, rod journals as well as main journals. This leaves the piston .031 in the bore. Possibly mill the block .030 and check for clearances. Ask Clark about mls head gasket thickness for correct/safe crush thickness. Also ask about material expansion to see if a longer rod will expand with heat as piston rings do.
Compression height is from center of wrist pin to top of the piston. These pistons are 1.105. The eagle rods crs6460O3DL19 are 6.460 the LR4 crank being 3.268 has a radius of 1.634 all totaling to show at TDC to be 9.199
Block deck height is advertised as 9.240
9.240-9.199=.041
Let's check with a kit with same pistons
1.105+2.000"+6.125"=9.23
9.240-9.23=.01 clearance.
With 6.460 rods the clearance would be .041 mill .030 leaving .011 clearance slightly decreasing static compression by ~10%?
L92105065P25
Which is .366"
Which is 6.491
9.240-9.199=.041
Yeah, destroying will never work, lol https://www.youtube.com/watch?v=52pNnE_jN3U
so your saying throw away a $1000 set of pistons so I can go with a different set of pistons and rods? Is there any geometry behind that? I can order a $590 set of 6.460" rods and have the block milled .030 for less $. If there is any geometrical/durability reason to support your idea I am all ears but I couldn't justify doing that just to go with more common parts. This engine will see 18-20 psi btw
Yes, I was being Sarcastic, you didn't see the grin on my face.
And it was 540 not 504. I am a fan of big bore short stroke myself.
Seems like there has been debate on ls1tech before about what you are
contemplating, so i thought I would throw that video on here for the fun
of it. Good luck with the build, keep us posted on the build, would love to
see results.
see results.
It would have been cheaper the way I suggested and not having to deck the block.
P.S. you would'nt have throw the other pistons away, it's possible tp sell theme.
Gt=alms
HI GT, yes I agree most here know LITTLE about PROFESSIONAL Racing.
I acquire my 3.268" crankshafts from David @ Marine Crankshaft, my neighbor.
He's a Kiwi, thus TOP quality Billets.
Your CASE, I would replace the piston, a Racetec 2618.
I will provide a good cost for the EXHATCH piston, I would hope to provide a NPR STEEL ring set.
I would NOT "deck" the block as few intakes will then fit.
The ALMS engine "spec" is COMMON, the chance to fine some "take-out" parts could also be possible.
Lance
Lance
Good morning everyone!!
hope everyone got a goodnights rest, I have been searching all night for something that will maybe... just maybe.. work! And I found it!! First I just googled 6.500" rod android came up to some forged rods for an old MG 4 cyl. Then right below it.. Howard's cams!!!!! Sbc large journal!!!!! Br6500 is the part number I'll post pics if I can figure out how comparing the ls1 style am for the sbc. If I remember right, when people were first modding ls1's (Jesus I was a kid) they were using 6.125" sbc rods before the aftermarket dedicated ls Rod was made. I remember my stepdad used a set and ran them for over 5 years before selling the car. (They were lightweight titanium and he wasn't about to throw them away) anywho... yeah only difference is a small offset on the pin I believe and the big end had a different size bearing but hey the big end bore Ian the same. Pin side width is .060 wider but what could that hurt? So the math side... 1.634(radius of stroke)+1.105 (comp height)+6.500(rods) 9.239.
Now as as for the lr4 crankshaft I'm finding that there are mixed answers for the stroke I'm seeing 3.268 and 3.270.. anybody know if this is a difference in year or if maybe it was a very used crank they mic'd?.?.
Destroke lq9
L92105065P25
Which is .366"
Which is 6.491
9.240-9.199=.041
L92105065P25
Which is .366"
Which is 6.491
9.240-9.199=.041
if I use the 4.8l crank and rods, with factory lq9 pistons and ls3 heads.. how much do I deck the lq9 block?
Why would you deck the block??
wannafbody (06-29-2024)
