My High Elavation 416 Build
I started a post earlier and never went anywhere .
So here I go again . We are about ready to assemble the short block and then move on to the top half .
Build so far .
Short Block .
New LS3 block
Texas Speed 4340 Crank
Texas Speed H Beam Rods w/arp 2000 bolts
Wiseco 4.070 piston -3cc
ARP main studs
ARP head studs
Sac City billet barbell
Holley # 302-3 oil pan
Melling #10296 High Volume High Pressure
Roll Master Billet gears and IWIS Pro chain
Long Block
Cam 236 248 @50 620 603 113+3
Morel # 6504 Lifters
TEA TFS 255 heads
Crowler Shaft mount roller rockers .
Smith Bros Push rods
Fast 102
VMAX Velocity ring
VMAX Ported LS3 T.B.
GM 42# injectors
Compression ratio 12.26
Hopefully it makes power !!
Build so far .
Short Block .
New LS3 block
ARP main studs
ARP head studs
Long Block
TEA TFS 255 heads
Fast 102
VMAX Velocity ring
GM 42# injectors
What are you doing with it and what are the numbers of that Cam Martin spec-ed for you? Those 42lb injectors might be a concern if you were looking for 550 or more rwhp. "416 build" catches my eye every time.
Did your ls3 block, require any clearancing to install the 4 inch crank?
Build so far .
Short Block .
New LS3 block
ARP main studs
ARP head studs
Speedtech oilpan w/ remote filter
Melling High Volume Pump
Long Block
Martin Smallwood spec cam
Morel Lifters
TEA TFS 255 heads
LS3 rockers w/ Straub kit w/ bolts
Push rods ??
Fast 102
VMAX Velocity ring
GM 42# injectors
Build so far .
Short Block .
New LS3 block
ARP main studs
ARP head studs
Long Block
Morel Lifters
TEA TFS 255 heads
Push rods ??
Fast 102
VMAX Velocity ring
GM 42# injectors
You'll probably have to space your windage tray a bit too. Not sure why notching the bottom edge of the bores is necessary for some but not others, it must be the rods in use. I did not have to with a 4.00 stroke and I beam rods on a 5.7 block.
Looks nice! I like the black valve covers and manifold, plus the clean fuel rails.
Really interested in the results
I'm estimating 640 horse at the crank.
I'd be surprised to see that high IMHO.
