How much oil - boosted w. stock pans
I believe some run upwards of 8 quarts with turbos. However if you don't experience sustained high G's you can use the full line on your dipstick as long as your turbos are primed with oil
How many passes on your new setup?
It does. Sounds running an extra quart or so is a good idea. I thought so, but wanted to verify.
No passes yet! Haven't had time. So far on the street my logs look fine running the 7qts.
we used it on a fox body swap. fits nice, but the ******* oil drain plug was tapped for some random *** thread like m14x1.75.
summit offered to swap pans...but it was in the car already so we just turned one on a cnc at work.
moral of the story, check that your drain plug fits before you install it
or better yet use a ctsv pan. its cheaper and does the same thing
i use them on all my personal swaps (chevy trucks) but i'm 99% sure it woud have fit with the AJE k member we used on the zephyr wagon
you can get them for ~150 as new take-offs on ebay
just make sure you get the pick up too.
the dipstick and the windage tray are the same as the truck stuff so dont sweat that
My turbo 5.3 sbe just spun 2 rod bearings last week. #2 & #4 i was running 6 qrts of rotella 15/40. Its a truck pan setup with turbo drain right below starter. -10an drain and -4 feed. Do u think running 6 qrts could have been my issue? It lost oil psi on a street pull. No knock etc. Just low psi once warm.
I recently didn't check for awhile and it got down to 5 quarts seeing a drop in pressure to 20ish psi from the normal 35orso.... fresh 6.2 quarts and filter and all good
